Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 49
Like Tree1Likes
Thread: 2010 300c chugging?
  1. #16
    EvilSRT's Avatar
    EvilSRT is offline 3rd Place
    Oct 2011
    MN
    **** yeah! Glad you got it fixed!
    Dressed up by Billet Technology
    Stopping courtesy of R1 Concepts
    Gettin' low on Street Edge Coils
    Rollin' on Continental Tires
    Hangin' with the
    FNLX Crew
    Hemi Registry #1639
  2. #17
    Mikystyle's Avatar
    Mikystyle is offline Sim Sim Salabim
    Jan 2012
    Granite State
    Well technically not fixed. It's an intermittent problem and it's acting up again.
    Noticed it real bad yesterday. Lower rpms with some load it bucks and lags. I can get it to downshift if I give it more throttle but if it doesn't down shift then it's annoying. Snapped a video of it acting up, I'll get them up later today. Having the corsa exhaust helps because u can really hear it struggling. Im starting to wonder if the tranny is slipping a little
    2010 300c AWD-
    Corsa Xtreme, LMI Hammer, InTune
    20" Charger Reps, Ventus V12s
  3. #18
    KingofKings2584's Avatar
    KingofKings2584 is offline LX Padiwan
    May 2011
    Orlando, FL
    I've been following this thread cause I'm having the same problem in my '09 charger r/t. Was hoping the camshaft sensor would fix it but apparently not. Hopefully we can figure this out because yes, it is very annoying. I'm at 37k miles and read that a transmission flush might help. Anyone try that yet with favorable results?
    Performance: Diablo Predator / 6.1 Headers and mids / Solo Performance SRT Cat-back exhaust / LMI Hammer intake / Jet 180 t-stat / Mopar SRT Suspension / Stack Performance Chubby-Pro Sways / Razors Edge Front Strut Brace / General G-Max AS-03 255/45/20's
    Appearance: Challenger SRT rims / Honeycomb Grille / Charger script emblem in Grille / 6000k HID's / 5% Tint / Random Billet Bling
  4. #19
    Daphod74 is online now still. accumulating. parts.
    Dec 2011
    Apex, NC
    Check your EGR - mine was failing slowly for months and I was getting bucking/surging with light throttle. I replaced the MAP, Cam position sensor and PCV - which helped a little but didn'ty solve the problem. One day it felt like it was going to stall and finally gave me a code which pointed to the EGR. After replacement, the car is smooth in all ranges of the throttle.
    2005 300C Magnesium Pearlcoat
    BBK 85mm TB, Volant CAI w/lower duct,
    2006 TCM swap
    DS Predator 91 CAI canned tune
    180* t-stat
    Borla cat-back 140112
    SRT struts/springs + Hotchkis sways
  5. #20
    Mikystyle's Avatar
    Jan 2012
    Granite State
    Ok, here are some vids i took. Again better if you listen on computer speakers and the changes and fluctuations in the exhaust tone is what really shows the problem. The second video is a little easier to hear it. In this videos, my throttle postion stayed the same and did not fluctuate but yet you can here fluctuations in the car and see it slightly on the needle.
    As far as the EGR goes, I know in my Ford Diesel truck, they make kits to remove the egr/bypass it. Anything like this for the LX? if its causing problems and I can remove it you best believe it will be outter here.
  6. #21
    EvilSRT's Avatar
    Oct 2011
    MN
    BT makes an EGR delete.
  7. #22
    Dec 2011
    Apex, NC
    You could try disconnecting the EGR electrical connector temporarily - you'll get a code and I think MDS won't work, but you test the theory at least (should be smoother if it is indeed the problem).
  8. #23
    May 2011
    Orlando, FL
    The '09-'10's don't have egr if I'm not mistaken, at least not a block off section. But I don't know what it could be. It seems like the tranny doesn't know what to do, doesn't want to downshift when you need the power, hesitates when you want to go. I thought resetting the TCM would help but not really. Some days car runs great, other days you wonder whats going on. Definitely frustrating.
  9. #24
    Mikystyle's Avatar
    Jan 2012
    Granite State
    Well, i think its the tranny. I think it might be slipping. Its getting worse and today when getting on an on ramp under a load of about 3k rpm it felt like the car was jumping a little so I called my Stealership and its going in next week. Took my Intake and Intune off so they cant pull any "voided warranty" crap. Ill post back when I find out what it is.
    Im not taking my exhaust off but i cant see that having any issues with the warranty right? If its the tranny Id hate for them to say its cuz of the exhaust and then I have to cover it.
  10. #25
    Hank1946 is offline LX Padiwan
    Oct 2009
    California
    Quote Originally Posted by ToDieFor View Post
    My SRT8 does something very similar. It just feels like it bogs for a split second then after that it's smooth through the power band. I was planning to change the plugs and cam sensor to see if that helps.
    It is not your plugs if it were it would not go away. It would get worse under load.
  11. #26
    Oct 2009
    California
    Quote Originally Posted by Mikystyle View Post
    If it is still under warranty take it to the dealer it might have to be updated by computer and only they can do it!
  12. #27
    Mikystyle's Avatar
    Jan 2012
    Granite State
    Quote Originally Posted by Hank1946 View Post
    That's another option I was thinking it might be us a computer issue. It's at dealership now. Post back when they find it, if they find it...
  13. #28
    Mikystyle's Avatar
    Jan 2012
    Granite State
    Dealer called this morning. Said they couldnt find anything or really feel any problems on the test drive (I knew that would happen). So it looks like Im going to have to diagnose this myself or wait till it gets even worse to the point where they will feel the problem. They did find worn out outer tie rod ends so atleast my trip wasnt wasted.
    I mentioned the EGR and mechanic said that if anything was wrong with the EGR it would throw a code and I have no codes. Could anything be wrong with the computer or EGR and not throw a code?
  14. #29
    Dec 2011
    Apex, NC
    Your EGR could be acting up without throwing a code. Mine did. I replaced the cam position sensor, PCV, cleaned TB, etc and nothing made the rpm surge go completely away. I drove it with the surging/hesitation for a few months until it got really bad like it wanted to stall - and then finally threw a code for EGR. Once it was replaced, the car felt 100% normal again.
  15. #30
    Gdragich's Avatar
    Gdragich is offline Keeping it Green with MDS!
    Mar 2009
    Arlington, WA
    As stated before, 09+ 5.7 Eagle engines do not have EGR. Only pre 09 have EGR. If confused, look at front of intake manifold on passenger side near the intake tube and you will not see and metal canister or metal tube connecting from head/exhaust to intake.
    Sent from my SCH-I405 using Tapatalk 2
    2005 Mineral Gray AWD Hemi Registry # 1154 Comp Cams 260 cam, Blastin' Bobs 9db, Dual Flowmasters, Gibson Shorty Headers, JBA High Flow Cats, Frankentake CAI, Techco Strut Barce, Taylor Shorties, 180 thermo, 85mm TB, Flastech Halos, Predator-tuned by Diablotoona. 2008 Magnum BB R/T Hemi Registry # 1584 PPP Stage 2 Cam, JBA Shorty Headers, JBA High Flow cats, Heartthrob Exhaust, Eagle Intake, 85mm BBK TB, LMI Intake, SMF Strut Brace, lowered, Tuned by Diablotoona
