How hard is it to replace the thermostat and where is it? I am not next to my car at the moment and wont be for about another month. Well anyways justy trying to get an idea of how hard or easy it is going to be to change it out. Thanks
2009 Challenger SRT8
AFE Cold Air Intake
Zoomers Catback with 3" X pipe
Right here...Take the two 10mm off that is holding the holes on..It is pretty easy,just messing(probably because I never try to save the coolant)...LOL The same way you took the old thermostat out you put the new one in...BTW don't forget to Burp the motor when everything is sealed and done..
Attachment 18257
Lol! Thanks!
Yes, it's pretty easy.
The only thing I'll add is to use a large zip lock bag to catch the coolant after loosening the bolts or not.
Here is the easy step by step with video: LX Thermostat Changeout Video *
Takes about 15-20 minutes.
2008 Magnum BB R/T Hemi Registry # 1584 PPP Stage 2 Cam, JBA Shorty Headers, JBA High Flow cats, Heartthrob Exhaust, Eagle Intake, LMI Intake, MTCM, Techo Strut Brace, lowered, Tuned by Diablotoona SOLD--2005 Mineral Gray AWD Hemi Registry # 1154
on a stock engine would you say that t`s worth it ?
I woulndt want to loose some gas mileage ....
what are the benifits ? any negatives ?
protouring 84 cutlass: 450hp LT1+ 700R4 +9.5" t/c 3200rpm + ford 9" ,4 wheels disc brakes ,lowered 2" ,4 link , tubular A arms .....
CJ7 jeep,4.0L 250HP, AX-15,dana 300 +tera lo, soa , 36 iroks, dana 44`s,4:10 ,auburn ected,s ..
and finally a "cool vanilla" AWD RT magnum .
Should have SRT heads, intake & exhaust soon!
The 170 threw codes in early morning dur9ing the inter. The 180 doesn't, and I found little performance difference.
I gained >.5 mpg with the change
Just a grocery getter!
you do not have to. The car will run cooler at higher speeds only.
Around town the fans will not work until the factory settings, so the change will be very small.
All you need is a Predator.
Steve
06 300C SRT8
does anyone havea model for the 180 stat? can i buy it advance auto?
Slammed300c
2005 300c
BC Coilovers
22X9 / 22x10.5 DUB ONE's
I would go with the Jet one. I have the autozone one, and it isn;t very accurate-opens at 176, so I get codes constantly. I am awaiting a Jet to replace so no codes. If it opens too soon, too often you get the codes. No biggie-I can clear with Superchips, but just makes the heart skip a beat when the engine light goes off just as you have merged into freeway traffic!
