Results 1 to 9 of 9
Thread: Window problem
    Jul 2004
    Toronto, Canada
    Question Window problem
    I have looked for other references to this problem and I have had no luck. The right front window will only move 3 to 4 inches per press of the switch, either driver or passenger side. This applies to up or down. Full down or up requires 6 to 8 switch depressions. This has been an intermittent problem, works for 2 months, problem for 2 days. It is now permanent. I took it to the dealer and they replaced the regulator (5065474AE per service documents) and declared it fixed. It isn't. Any ideas on the faulty component?
    ____________________________________________
    2008 300C Brilliant Black Crystal Pearl
    BUTWEET's Avatar
    BUTWEET is offline GOOD MEAT TAKES A LONG TIME!
    Bothell, WA
    Please hold! Fnkychkn will be with you momentarily.
    MY MEAT WILL MELT IN YOUR MOUTH....NOT IN YOUR HANDS! ENJOY THE Q.
    fnkychkn's Avatar
    greasy cardboard box
    is this using the auto feature or even while holding your finger on the switch?
    marmaduke's Avatar
    marmaduke is offline LX Padiwan
    Feb 2006
    Toronto
    I have the same problem with my drivers side window. Works for two months and then one day it decides it's not going to have the auto up or down feature. Then next day it works again....
    2006 300CSRT8 - 2006 MSRT8 - 2006 GCSRT8
    MikeEast's Avatar
    Ducktown, Georgia
    Sounds like maybe they undersized something in the windows department on our car? (bad drivers? ) My left rear will stop working every so often and apparently dealers won't replace much without actually seeing it themselves.
    While I realize Rule#1 applies to almost every 'customer based' transaction, even when I showed them VIDEO of it not working they still didn't fix it.
    Is there some area that needs a bit better lubrication or something? Bigger Motors? More Power?
    Mike
    Jul 2004
    Toronto, Canada
    This is happening even while holding the switch down. Press the switch and hold, the window moves 3 to 4 inches then stops. Release the switch and repeat, same thing both going down and up. Same symptoms from drivers door switch and passenger door switch.
    Smoove06CSRT's Avatar
    Smoove06CSRT is offline Kiss my Rims.. They gots BIG lips!
    Nov 2005
    sounds like the windo weather stripping is causing extra force on the window. this extra force will put a strain on the window regulator motor. this motor has an internal thermal swithh ( breaker ) that will open and reset itsself after the current goes below the specified level.
    have your dealer inspect the window track and look for any type of obstruction or abnormality.
    this will fix the problem i hope.
    2006 300cSRT8
    Fastest color...... Bright Silver Met.
    "OHH! A Strip Club.....I'll Get my sweat pants on!"
    ZMagnum's Avatar
    Tucson, AZ
    rohoni is offline LX Newbie
    The windows that you have in your car always have a window regulator that makes them go up and down. These regulators usually convert the rotary motion of the motor into the linear and vertical movement of the windows. A problem in window regulator usually results in windows that are stuck in the up position, the down position, or somewhere in between.
