Results 1 to 15 of 15
    rickf28's Avatar
    rickf28 is offline I wanna go faster!!
    Nov 2007
    Sumter, SC/ currently Iraq
    Want to Remove Chrysler Emblem on Trunk
    On the 2006 300C is the emblem just taped on or is it mounted to trunk..I want to remove it but I dont want to have to take it to body shop either....Thanks
    My Name is Rick
    Cars Name is Alice
    SEE SIG ABOVE plus....Lots of BT goodies inside - Lots of custom aluminum inside, Factory REC Nav
    AAC HID fog lights - LED smoked tail lights...with LED bulbs - LED everywhere inside and out
    More to come, Im a broke A$$
    BIG SMOOTH's Avatar
    BIG SMOOTH is offline Just chillin' Dago style...
    Nov 2007
    San Diego
    Warm it up a bit with a hairdryer then use some fishing line and saw it off! Piece of cake!
    Then use some goo gone or something to remove the left over 3M tape residue (if any).
    rickf28's Avatar
    Nov 2007
    OK thanks...I debaged the rest of my car...when I went to do the trunk emblem it felt like there was something there stopping my fishing line so I stopped...I just wanted to make sure it wasnt mounted to the trink with rivits, pins...ect...
    My Name is Rick
    Cars Name is Alice
    mgrasber is offline LX Newbie
    Feb 2009
    Rick - as long as you're talking about the emblem and not the silver wing, you should be able to follow smooth's directions. If you're talking about the actual wing, there are two holes underneath it where its mounted on the trunk and you'd have to have those welded/painted if you remove that.
    rickf28's Avatar
    Nov 2007
    Quote Originally Posted by mgrasber View Post
    Guess I should have been more clear.....Yes thats what I want to remove...the whole wing....Thanks...I figured that there where pins....Guess Ill stop by body shop and check price..they should hook me up as many front ends as ive had replaced...lol
    All I want back there is the SRT8 badge
    My Name is Rick
    Cars Name is Alice
    Feb 2009
    haha yea I'm sure they owe you a bit of a discount if that's the case. I took mine in for a quote and they came back with $400 - let me know what they tell you. I'd be interested in seeing if your estimate is in the same ballpark.
    rickf28's Avatar
    Nov 2007
    No prob...im in Iraq now..ill be home in couple weeks...ill check then
    My Name is Rick
    Cars Name is Alice
    BIG SMOOTH's Avatar
    Nov 2007
    San Diego
    Quote Originally Posted by rickf28 View Post
    Well then my original instructions won't work.
    DIY, no bodyshop, this is simple, just takes a few minutes.
    For the wing, yes there are two small mounting studs behind it. You want to slice until you hit the stud then use some cardboard and slide it under the edge of the wing you've already "lifted" to kind of prop it up (but don't break it, use a skinny piece of cardboard) so you can then feed the fishing line through the middle section of the wing (like threading it through) between the studs and continue on, etc.
    It works better when it is warmed up or has been sitting in the sun to heat up. There will still be a lot of tape residue so take your time with that.
    Hope this is more clear to you as well.
    omega145's Avatar
    omega145 is offline LX Padiwan
    Feb 2009
    Long Island, NY
    ^^^But won't that need to be filled and painted anyway Smooth?
    BIG SMOOTH's Avatar
    Nov 2007
    San Diego
    Quote Originally Posted by omega145 View Post
    Yes, if he's leaving it blank with no wing at all.
    No, if he's going to put a different type of wing on there.
    Feb 2009
    I think besides the SRT8 badge he wants to have a naked trunk. But smooth is right you can still "fish" the wing off of there without taking it to a shop if you're just replacing it with a different wing.
    rickf28's Avatar
    Nov 2007
    Yep Naked trunk...all i want back there is SRT8 badge, tail lights and exhaust tips..
    Thanks for the help every one
    My Name is Rick
    Cars Name is Alice
    wheelman99's Avatar
    wheelman99 is offline the new guy
    Aug 2009
    augusta ga
    does anyone know if the 300c badges on the fenders have the same pins?
    BIG SMOOTH's Avatar
    Nov 2007
    San Diego
    Quote Originally Posted by wheelman99 View Post
    Nope, those are straight 3M tape, heat up and fishing line should do the trick.
    wheelman99's Avatar
    Aug 2009
    augusta ga
    cool thanks
