Results 1 to 12 of 12
    beerchamp is offline LX Newbie
    Sep 2009
    Speedo quit working
    I own a 2006 300limited, the speedo quit working, all other gauges work? any ideas.
    I don't have the funds to take it to the dealer- its been out of warranty for 1 1/2 yrs.....
    fuzzycali's Avatar
    fuzzycali is offline Space City LX Nawfside AC
    SPRING,TX
    What engine size and do u have abs?
    2007 Charger Road & Track R/T
    Fast56k's Avatar
    Fast56k is offline I ain't no FRI baby!!!
    Mar 2006
    Trans output shaft sensor.
    C.
    Silver 06 CSRT-8
    Fast56k's Avatar
    Mar 2006
    Check for codes.
    C.
    Silver 06 CSRT-8
    Sep 2009
    Its the 3.5 V6, yes it has ABS....
    I haven't rented an OBDII yet,
    How easy to fix; Trans output shaft sensor?
    Cost?
    Fast56k's Avatar
    Mar 2006
    Quote Originally Posted by beerchamp View Post
    Cost?
    You can turn the key 3 times and it should read out on your dash if it has codes.
    C.
    Silver 06 CSRT-8
    2005rtmag is offline 2005rtmag
    Wilmington, N.C.
    Does your cruise control work?
    My speedo failed on my Mag at 5k miles and the instrument cluster was replaced under warranty. Have no idea what it cost but I'm sure it would be significant. My cruise still worked so it must have had some speed input.
    redinorange's Avatar
    redinorange is offline Curmudgeon
    Nov 2004
    Orange, CA
    Quote Originally Posted by 2005rtmag View Post
    I have the same problem. According to fnkychkn, a new cluster is about $1200...
    Attitudes are contagious. Mine might kill you.
    Sep 2009
    Cruise control works...... pass on fixing it for $1200, I borrowed my friends Garmen and the speedo on it works just fine if I go on any long highway trips...........
    Fast56k's Avatar
    Mar 2006
    I found a bunch of speedometers on ebay cheap.
    http://shop.ebay.com/i.html?_nkw=05+...gnum&_osacat=0
    C.
    Silver 06 CSRT-8
    Chrysless25's Avatar
    Chrysless25 is offline LX Padiwan
    Jan 2009
    new orleans
    I actually have a spare speedo for 06 3.5 touring. I believe it has forty something close to 50k
    Illini 300C's Avatar
    Illini 300C is offline LX Padiwan
    Mar 2009
    Champaign/Galesburg, IL
    While it's older and less refined tech, my 98 Wrangler would occasionally have all the gauges fall flat at random times while driving. A quick bop or two to the dash brought everything back to life. Eventually I just took it apart and cleaned the connection and it disappeared.
    Anyone have insight as to what causes the failure on an LX? Is there even the possibility for a dirty connector?
    2006 Chrysler 300C Heritage Edition. Representing the Midwest and MoPar for 23 years.
    Add Me on Facebook
