Results 1 to 15 of 27
    Slick Magnum's Avatar
    Slick Magnum is offline Almost a year old & still loving it.
    Apr 2006
    Toronto
    remote starter fix
    So I have been having problems ever since the dealer installed the remote starter on the 300c. Rarely worked in my driveway & the wife said it always works at work & at the malls. WTF??!!
    Then it hit me. she always parks behind me in the driveway & it has a slight slope to it. Turns out that when we back it into the driveway, it works!! It must be the hood switch!! Problem is, we have such a dark tint on it, it's hard for her to back into the driveway at night.
    So, if I cut the wire to the hood switch, will the remote starter still work? I already unplugged th horn wire from both cars so we don't piss off the neighbors.
    fnkychkn's Avatar
    greasy cardboard box
    no it will not. the wire to the hood switch must be grounded in order for it to work. you can try adjusting the angle of the switch. vehicle level with the hood open, the switch should be at a 45* angle.
    SmoovC's Avatar
    SmoovC is offline M45 Maniac
    Apr 2006
    Graham, Kracka'!
    You could also ditch the merc switch, install a pin switch, and wire through a SPDT relay as follows:
    pin 85 to the switch,
    pin 86 to 12 volts constant (battery),
    pin 30 to ground,
    pin 87A to the hood input of remote start unit.
    The R/S will see ground until the hood is opened.
    2006 Infiniti M45: Diamond Graphite Metallic, Premium Package Option Group w/ Mobile Entertainment System, Tein H-Techs & KYB Lowered, Magnaflow Exhaust
    2000 Dodge Dakota C/C R/T: Flame Red 5.9L, 1 of 800 Produced, Belltech Lowered, 20" R/T Replica Wheels, Flowmaster Exhaust
    More pics at:
    Visit us at:
    Token's Avatar
    Token is online now First AWD LX in the 12's N/A
    Center of the LX Universe
    Or just pull the switch all together, and just ground out that wire.
    12.645@108.18
    Super T's Avatar
    Aurora, IL
    I grounded mine
    PaulFix's Avatar
    PaulFix is offline Mr. White Chocolate P. Rock
    May 2005
    BC, Canada
    I grounded mine also, but applied the sticker
    Dodge Magnum RT AWD MDH=Jan 19th 2005 7-8pm
    Tow package, Midnight Blue, Painted spoiler body colour, Auto headlights, HID lows, Fogs on with Hi beams, SC flash with custom tranny and 91 tune, RER MyGig installed, Tranzformer, Resonators deleted, Custom Stainless intake.
    160,000km driven very hard, repairs include replaced front brake rotors and pads $200, rear pads$, ebrake shoes, all 4 tie rod ends $50ea (only 1 was loose), front sway bar rubber bushings $25(first thing to check if front is clunky); 3m refinished headlights WOW $30, 4 sets of tires, 2 tranny filter and flushes,
    lower8 is offline The weekend heals us!!
    Dec 2006
    N.W. Phoenix
    Quote Originally Posted by Magnum Maniac View Post
    pin 30 to ground,
    are you sure there is a merc switch?
    SmoovC's Avatar
    Apr 2006
    Graham, Kracka'!
    Quote Originally Posted by lower8 View Post
    If am understanding fnky's post correctly, there is.
    Aftermarket systems work the opposite way: if they see ground, they will NOT start. The Mopar system needs to see ground in order to start.
    More pics at:
    Visit us at:
    fnkychkn's Avatar
    actually, it's a ball switch. when the ball reaches the end of it's travel, it closes the switch contacts.
    the new kits now come with a different switch that no longer grounds through the chassis. it's now a normally open switch and the circuit returns to the module.
    RobAGD's Avatar
    Reston, Va
    After much frustration in cold weather I cut the hood switch out of mine and grounded it. The Horn I added a cut switch, so in the AM I can set it to off and no horn, when I get in I turn it on and when I start it through outthe day I get the little honks. Kind of helpfull this time of year finding the car in the crowded lots.
    -R
    LowGo's Avatar
    LowGo is offline Alter ego of MyMaggieMae...
    May 2005
    Gresham OR
    I've always had a problem with my remote start not working at random times. It does this even in my garage, which is level, so I don't think it's the hood switch. I've tried to figure out a pattern to it's behavior, but can't find anything that's consistant. I was wondering if there was a way to decifer why the car won't start. All it does is flash the lights at me, with no way of knowing what's causing the problem.
    Inferno Red '05 Magnum RT AWD - Who says the AWD sits too high?!
    German influenced garage queen .................... German engineered daily driver
    Token's Avatar
    It's still likely the hood switch that's causing the problem. I've had the same thing happen when the switch was installed.
    The ball switch is a poor design, the simple vibration of the engine starting can move the ball and break the contacts. Causing the car to shut off.
    Or if the ball is not in the exact right position, the contacts will not be closed and the remote start will not function.
    This was an internittant issue when the switch was in place, as my driveway is also level, but since the removal of the switch, has never re-occured.
    Only way to eliminate this possibility is to remove the switch and test it.
    12.645@108.18
    LowGo's Avatar
    May 2005
    Gresham OR
    Quote Originally Posted by Token View Post
    Thanks for the info. I'll have to do some testing on that switch and see if it fixes my problem.
    fnkychkn's Avatar
    Quote Originally Posted by MyMaggieMae View Post
    the clue is how many times it flashes. please describe the exact sequence of events that occur when it doesn't start.
    LowGo's Avatar
    May 2005
    Gresham OR
    I knew you'd ask me a technical question like that! As I recall, they always flash twice (but don't hold me to that... I'll have to pay more attention next time). I push the remote start button twice... you can hear it do some stuff (little clicking noises)... then the lights flash back at me twice (what I call the "screw you, I'm not starting" signal)! I've disconnected the noisy horn, so I don't know how many times it would honk (twice too, if I remember correctly).
    I had the hood up tonight, so I decided to just bend the switch down a little to see what happens. I've used the remote start 3 times since then, and it's worked each time. We'll see if that holds.
