Rear subframe/ rearend bracket ?
Does anyone know if there is a difference between an 05' 300c and an 06' 300srt8 subframes. I own both and the srt8 is the parts car and i want to swap rearend and axles to my 300c. But the subframe may be bent on the srt8, so im curious if it is, if i can just swap over the rearend, axles, spindles and brakes without having to swap subrames with it.
i don't believe you have to swap the subframe for this. rear portion of the drive shaft will need to be changed to a 4 bolt though to mate to the 3.06 rear end.
Thats what i wanted to hear, i have the drive shaft also.
Thank you
- You may not post replies
- You may not edit your posts
Forum Rules
