Results 1 to 15 of 28
    c4m
    c4m is offline LX Newbie
    Mar 2008
    OBDII Not Ready HELP!! (Cant Pass Inspection)
    Hey guys I'm having an issue with my 2005 300c AWD with 45,000miles. I recently took my car to NJ State inspection and failed for OBD Not Ready. I have a diablo predator with a 93 octane tune and had gotten the inspection done with my tune on. As soon as I failed I automatically figured it was the predator tune. So I went back to stock and went to inspection again but I still ended up failing. At this point I am still running with my tune off and figured maybe I needed a full drive cycle untill the OBD becomes ready. Searching around on the board I found that if you wait 15 seconds with the key position to on if the CEL blinks it means OBD is not ready. I've driven at this point over 300 miles and my OBD is still not becoming ready. My next step is simply to take it in to the dealer, but being an 05 with 45,000 miles im sure none of this will be covered under warranty. Before I do this I wanted to get some help, advice, or suggestions from my fellow LX members. HELP! Any info is much appreciated and thanks in advance.
    dpshook's Avatar
    dpshook is offline LX Padiwan
    Feb 2008
    check the fuse for the power. I dont know which on it its. also have you tried to unplug the battery and let it reset?
    I eat through end links like candy bars!
    c4m
    Mar 2008
    Sorry I forgot to leave that out. I actually did leave my battery unplugged overnight and reconnected in the morning to do a "full reset" of everything.
    PowerWagon896's Avatar
    PowerWagon896 is online now Clever Disguise as a Responsible Adult
    May 2006
    Waiting on the gravy train
    Quote Originally Posted by c4m View Post
    DO NOT DO THAT!
    Everytime you do a reset it will reset the not ready condition.
    dudeiwin86's Avatar
    dudeiwin86 is offline Dude...
    Houston, TX
    yea dude.
    you have to drive like 50 miles on the car to get it to learn read all the sensors.
    if you reset anything it will give NOT ready.
    if you wrote a tune, or went back to stock.. NOT ready, it starts over.
    go drive for a while, do 75 mph in 5th gear
    then do traffic, or light to light
    different types of driving finish it faster.
    check with the Key to see if the CEL blinks, if it doesnt, then go get inspected.
    c4m
    Mar 2008
    After failing the second time for not ready I decided to do this. As I said earlier I've driven over 300 miles since unplugging the battery. I mean just continuing driving may resolve the issue but I guess only time will tell. But I would think 300 miles should be sufficient for the system to become ready, but I can be wrong..
    PaCharger's Avatar
    Oct 2005
    Supercharged 2012 Audi A6
    took me 3 key cycles getting to temps, about 18 miles.
    PaCharger's Avatar
    Oct 2005
    do you have the temp code turned off in your tune? o2 sensors? give us some other details....
    Carfinish's Avatar
    Carfinish is offline Capeeesh!?
    Nov 2005
    White Plains NY
    read this ... should help you a lot
    http://www.lxforums.com/board/showth...31#post2058431
    RIP
    12.869 @ 102.02 Stock 5.7 w/ C&L, Predator, JBA Cats, Volant catback, DRs & skinnies
    c4m
    Mar 2008
    I did not make any other changes with the predator besides the 93 octane tune and the typical quick adjust settings. And again about 300 miles ago I went back to my original backup so the car is now back to stock.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Do you have a colder T-stat?If the car does not maintain 167*and above for the entire test cycle it will not test for ready status.I know most people have 180* T-stats but if it's cold out then it is possible not to maintain 167*+.Also you need to maintain highway speeds for some distance.I would bet your Thermostat is the culprit.....also you didn't mention if you had an engine light,if you do it's an instant fail.
    BFNY PERFORMANCE
    RIP My Friend
    c4m
    Mar 2008
    I have not changed out the T-Stat. I bought this certified used from the dealer so it is possible that the previous owner changed it. But I have no way of knowing. I do get the "coolant not reached optimum temperature CEL" (I forget the code number) from time to time that I simply clear with my diablo. But I dont know if this means anything.
    Hemi31's Avatar
    p0128?That would be the t-stat.If the temp needle is not on the center line or above on the highway you have an aftermarket t-stat.If it's about a 1/4" off to the left of center you might have a 170* and you'll never get to ready without really working at it.
    BFNY PERFORMANCE
    RIP My Friend
    c4m
    Mar 2008
    Yes its the p0128. With the colder weather it does take a little while but it does eventually get to the middle line or at least very close to it.
    Hemi31's Avatar
    Easiest thing for you do do is go buy a stock t-stat,put it in,go drive 100 miles and pass inspection.You can put the cooler t-stat back in for the summer.
    BFNY PERFORMANCE
    RIP My Friend
