OBD Light
I love my new 300 Hemi C but my OBD Light keeps coming on.
I have taken it to the dealer twice but to no avail.
Is anyone else HAVING this problem?
Frustrated
OBD
Do you know what the codes are or what the dealer says the problem is?
If it's O2 sensor related, perhaps there are some small leaks around the O2 sensor bosses FROM incomplete welds.
Good luck!
OBD Light
The 1st time I took it in they said the gas cap was on too loose,I doubted that because that's the 1st thing I checked.
The second time I took it in the Dealer Rep talked in language I couldn't understand.Something about the wheel might have slipped and caused a imbalance between the motor and transmission.
But after three days it came on again. Frustrated
OBD light
You aren't "two foot" driving are you? hitting both the brake and the gas at the same time can set a fault code.
- You may not post replies
- You may not edit your posts
Forum Rules
