Results 1 to 8 of 8
    marmaduke's Avatar
    marmaduke is offline LX Padiwan
    Feb 2006
    Toronto
    My New Winter Wheel PKG - Installed
    Installed New Winter Tires and Rims...
    Had the winter rims and tires installed last night. I watched from the sidelines and they did a great job, balancing, installation, and the price was the best I could find.
    The 18" rims fit with only a hair to spare in clearing the brake calipers on the front. See photo....
    I went with a staggered set up, TSW Thruxtons 18x8" w/Nokian WR SUV Vspec 235/60/18 front, and, 18x9.5" w/Nokian WR V Spec 255/55/18 on the rear. I really like the 9.5 wide rim. Looks LARGE!
    2006 300CSRT8 - 2006 MSRT8 - 2006 GCSRT8
    JonzMgnm's Avatar
    Jan 2006
    Commack, New York
    Nice, Marmaduke!
    Talk about tight clearances.....sheesh!
    John Y
    MAGNUM8R's Avatar
    MAGNUM8R is offline Yes I am a pirate, 200 years too late
    So. California
    Nice, looks like some painted splash guards would help U out seeing that last photo!!!
    An over 40 victim of fate.
    '8R'05 Magnum RT Midnight Blue Pearl
    KW V 2 , Hotchkiss Sway Bars, CF Airhammer intake,T Rex Billet Grille, Body color Airtab Vortex Generators, Chromed stock 18's BFG KDW 255/55/18 Tires,Avon splash guards, Gibson Performance Stainless SteelHeaders, GibsonCat back, SC 91 Performance tune.
    Hi Flo Cats
    marmaduke's Avatar
    Feb 2006
    Toronto
    Quote Originally Posted by JonzMgnm View Post
    Nice, Marmaduke!
    I'll second that, very tight...
    FYI -
    Also, I installed these without the wheel sensors. No TPM codes all the way home last night and my EVIC was indicating 4 good readings.
    I thought that perhaps the system kept the last known values? Then I realised I had my 4 factory rims and tires in the back seat, if this makes a difference (I thought the system was passive and required relative movement beteen the sensor and the pickup???) I'm not an expert by any means...
    Today however, I did get TPM codes. The system would peep once and then the tire (!) inflation warning signal would flash on the dash for about 1 minute then go away. The car now does this once every 15 minutes or so... Not that annoying... I am going to look for a fuse...
    Open to suggestions....
    marmaduke's Avatar
    Feb 2006
    Toronto
    Quote Originally Posted by MAGNUM8R View Post
    Thanks!
    I have the painted splash guards on the front and the rears are in my trunk. The rear units do not mount flush because of the SRT8 lower bumper fairing? I trial fit them on but there is a 1/4" gap up top (Looks sloppy...) I think I will try and trim them to see if I can get them to fit tighter before I install them??
    Any suggestions...
    grande prairie,AB, Canada
    so you didnt need a spacer right? this is the style i've been leaning towards after i saw them in adams thread.. only because these ones will be very easy to clean on the inside... from the outside..
    and well, they really show off the brembos
    but since that is my color, i've just made up my mind... thanks marmaduke.. mine go on order tomorrow!!
    one question though.. with the 9.5 inch wide rear.. what can you fit for width come summer time if a guy wanted to put some slicks on them.. could you go 295's?? just curious thats all..
    thanks again
    ALSO.... what is the offset on these wheels?
    marmaduke's Avatar
    Feb 2006
    Toronto
    The offset is +20 both front and rear. As for a tire size that will fit, I am not sure. With this offset it is very close to being flush with the outter edge of the fender. Perhaps a +35 would work better. Personally I like the wide stance look as it is...
    The reason I went with the 9.5 inch rear rims was for the same reason your thinking. I have a rim that will fit a nice sized slick, just in case...
    Cheers!
    Quote Originally Posted by jizzajames View Post
    thanks again
