Originally Posted by
D's300C
the three prongs arent to light up the switch. its the same with unlit switches. One is the ground for the switch, one is the power to the accessory (ie Halos), and the other is to the power source you are using (if i remeber correctly, one end is ground, center is power source, othe side is accessory power. the package of the switch will tell you which end is which)when you flip the switch to on, you are completing the power circuit. when you switch it off, you are basically disconnecting the power source from the halos. All the light does in the switch is get power from the completed circuit and lights up to tell you that the circuit is complete (ie, its turned on)
BTW, all four of my halos light up equally bright. I have AAC Halos.
Pm me a little later and I will try to get pics of my wiring tonight (as best I can w/o removing front fascia)
