airbag light is the connector to the clock spring, there is a TSB on it, the wires are too short: if you have the electric telescoping steering column, when the column extends the harness disconnects from the clock spring. Tell your dealer to run the TSB for the clock spring, they'll find it, and it requires the replacement of the clock spring, wire harness, and the plastic cover between the column and the dash that goes up and down with the steering wheel.
Took 5 trips to the dealer for them to fix mine correctly, if I hadn't been a member here and found the TSB they might still be working on it..
as for the odor, maybe a valet with bad BO, like that Seinfeld episode, or perhaps a tech with bad BO? I once had a buddy (yes once had, no longer) that thought it would be funny to put a Subway Tuna melt under the Seat of my 1996 Chevy Z71, he wedged it between the seat and console, must've been there for 3 weeks before I found it... talk about barf!!!!!!!!
I got even by having 35 of his co workers silly string him at a company breakfast meeting...
