Results 1 to 9 of 9
    supermag is offline Supermag
    Mar 2008
    tennessee
    Exclamation mECHANICS HELP NEEDED...PLEASE!!!!!!
    Hello I need everyone's help. I am the owner of a 15 magnum rt. 6 months ago the transmission startrd slipping after leaving my driveway one day. Being only 3 miles from my local dealer and being covered by my 6 yr 60,000 extended mile warranty (by 12 miles) ( my car had 59,988 mi) I immediately drove at 29 mph through back streets to the dealership where i was told that they hooked it up to the starscan and the transmission speed control sensor was bad and needed to be replaced and leave the car with them (which i did) later that day i recieved a call that said the tech. found "burnt" transmission fluid (their words) and that I would need to pay 100+ dollars for because it was not covered under the extended warranty, so i did. 2 days later I picked up the car and before i got home ( 3 miles mind you) the ececk engine light came back on so i turned around and went back to the dealer where they hooked it up to starscan and if flashed an incorrect gear ratio code. so he re-flashed the transmission again and it went away. Forward to today. I an leaving the house to go to work and as soon as I pull out of the driveway the transmission starts to slip and wont go into 2nd gear. So I call work and check the internet where it says to let the car warm up in cold weather (about 25deg. this morning) I strat the car and let it warm up for 20 min b-4 leaving for the dealership (Again 3 miles away) this time it will go into 2nd if i baby the throttle, but even the slightest puch of the pedel and it slippes completely out of gear and the engine revs. the only way i can keep going is come to a stop wait a few seconds and start again slowly. Well i recieve a call this evening from the Svc. dept. and she says that her transmission tech looked at it and determines that it needs a new transmission. I ask her what the Svc tech determined the problem was and she said that they havent cracked open the case yet to give me an exact diaignosis but that its nothing external and that it needs a new transmission to the tune of $3500.00 and that she could quote me on a rebuild but she said they dont last and its not worth the money difference. I know that there are some dealership svc techs. on this board. and was wondering if driving a car at 20 mph for 3 miles with only a speed control sensor wrong, after any sign of slipping will cause the transmission fluid to be burnt, or should the dealership looked harder at it 6 months ago when it was in warranty. I know dealerships have to do repairs at a reduced rate when charging chrysler or any other extended warranty provider. I tried calling chrysler but just got some guy in india that told me since i am the 2nd owner and did not pay 150.00 within 30 days of purchase that the powertrain warranty was not in effect. I would have done this because i was concerened about the powertrain at the dealership. However Alexander chrysler in Franklin Ky, did not tell me about this option as they knew that I would not have bought the extended warranty as I did.
    Any Help anyone can give me, especially from Factory Svc. Techs. would be greatly appreciated as I am now divorced paying alamony (unhappily), and Child support (Gladly) I can not afford 3500.00 plus tax, I simply don't have it would be greatly appreciated .
    Signed,
    PI(XX)ED OFF IN TENNESSEE...
    Scott Holbrooks
    "Supermag"
    imahemi is offline ...
    Feb 2007
    Omaha, NE
    how many threads do you need????
    -Ryan
    <<<clicky...
    '93 1500 SB - 226k, '05 Magnum RT - 17k, '80 El Camino - 84k
    Sick300 is offline D's Sick 300
    Sep 2008
    Lake in the hill's area
    dam thats messed up, Cheap ass dealership
    Not funded by Mommy n Daddy.
    HEMI-C's Avatar
    HEMI-C is offline HEMI-C
    Dec 2007
    Belton, Texas
    So you purchased a 60k warranty when u bought it or it was on it previous to the purchase? And it shouldn't matter since they did work to it for the speed sensor and all u paid for was what? It kinda sounds like YOU paid for the sensor. Trans fluid ain't a $100+...much less. And i guess your mileage is now 60k+ correct? If it was done under warranty it should still be covered. But if it was you that paid for the sensor and not warranty then simply put it... UR FCKED. If it was covered under your warranty then it was a previous warranty problem under the covered mileage then you should be covered being that they didn't fix the problem the first time. By the way the $100+ might have been the deductable if it was under warranty. Tell the service writer some of this and see what he makes up to tell u then...lol. I know i am one lol. If it doesn't come out the way you want it then start raising hell and someone higher up will get tired of hesring about it. Especially if he has to actually talk to you face 2 face.
    Enjoy,
    Justin
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    So here's my opinion.......2005 Magnum came with 7yr/70k mile powertrain warranties.......they usually had a $100 deductable after 36k miles.The dealer should be covering it under the powertrain warranty and if they are not I would bring it somewhere else.
    BFNY PERFORMANCE
    RIP My Friend
    cm2005300's Avatar
    cm2005300 is offline The New "Milli Vanilli"
    Bc
    they are not going to he /she didnt pay the second owner transfer fee of 150$ so no matter what there is no 7/70k coverage because once the car is purchased you have to transfer that for the 150$ within 30 days
    MOD LIST : NOT ENOUGH!!
    Hemi31's Avatar
    Quote Originally Posted by cm2005300 View Post
    Guess he's buying a trans then.
    BFNY PERFORMANCE
    RIP My Friend
    Peter Parker's Avatar
    Peter Parker is offline I just wanna go fast...
    Feb 2008
    Smashville, TN
    Or calling his attorney...not sure if that will help much though...
    Lopey: 6.1L N/A Modified / 3700lbs 473rwhp/439tq ~ Quickest ET : 11.152/117.5mph, 1/8 - 7.0/99.56, 1/4 Trap - 126.15mph <~ Sold
    R.I.P. Lou1355
    HEMI-C's Avatar
    Dec 2007
    Belton, Texas
    U still didn't say if they had done any work under warranty or not. If they did, its on them. Even though u said u weren't supposed to be under warranty, if they did work under the pretense that it was under warranty and then later found out that it wasn't.... their gonna eat the trans.
