Results 1 to 12 of 12
    albertojedi is offline LX Padiwan
    Sep 2009
    Puerto Rico
    Lighter Outlet Not Functioning (2006 300C)
    This morning I connected my tire air compressor to the lighter power outlet (the one next to the ash tray) and after a while it suddenly stopped working (BTW, the ignition was on). I connected the compressor to the center console outlet and it worked fine. During the trip I pushed the lighter button down to see if it started working again, but the lighter just stayed cool, meaning that it was not working. I thought maybe the corresponding ash tray power outlet fuse blew. However, after checking the Owners Manual power distribution center fuses identification, I'm unable to find the one corresponding to this power outlet. Page 331 of the manual indicates that cavity 18 corresponds to the Selectable Power Outlet fuse. Is this the one near the ash tray? What other possibility exists aside from a blown fuse? Any insight?
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    The fuse for the ash tray power outlet is in the rear fuse holder.Also is there a fuse in the plug of the compressor?
    BFNY PERFORMANCE
    RIP My Friend
    Sep 2009
    Puerto Rico
    I do not know if the compressor has a fuse. But as I mentioned, the compressor kept functioning after I connected it to the other power outlet (the console power outlet). So, I doubt the problem was in the compressor.
    Thanks for the info on the fuse. I will check it. Hope it is not another thing.
    Hemi31's Avatar
    there are two different fuses for the ashtray and console just so you know.
    BFNY PERFORMANCE
    RIP My Friend
    RossE's Avatar
    RossE is offline LX Owners of Waterloo Region Member
    Kitchener, Ontario
    The fuse is in the back fuse panel by the battery. I believe it is #18
    Mods: American Racing 20" Torque Thrust M's, Yokohama Parada Spec-X 255/40VR20, Daytona Chin Spoiler, Daytona Honeycomb Grill, Daytona Rear Spoiler, Aftermarket Fogs w/ HID's, Low Beam HID's, Blastin' Bob Dual Exhaust Conversion Kit, K&N CAI, Stock Air Silencer Removed, Tinted Windows, Tinted Tails, Hood Props, Debaged, Mopar Pillar Gauge Pod, Autometer Oil Pressure Gauge, Autometer Voltmeter, Flex-a-Lite Oil Cooler, Polk Audio 6.5's in Doors and Rear Deck, Infinity Reference 3.5" in the Dash, Infinity 311A Amp, 2 X 10" Infinity Subs
    Sep 2009
    Puerto Rico
    Effectively, the fuse number as indicated on the Owner's Manual is #18. Let's check it!!!
    Nuclearjack's Avatar
    Nuclearjack is offline I drive!
    Halifax Nova Scotia
    there is fuse 11 and fuse 18. one for the ashtray lighter and one for the cig lighter.
    I forgot which is which but try both
    Sep 2009
    Puerto Rico
    Thanks. Fuse 18 is for the cigarette ash tray lighter and fuse 9 is for the console power outlet. I verified fuse 18 it and it was blown. Substituted it and evertyhing worked fine again. Just hope there is not an unknown problem who is causing the fuse to blow off. Perhaps my air tire compressor was to much for it. Lets see.
    Eric Bryant's Avatar
    Eric Bryant is offline Member #20
    Feb 2004
    West Michigan
    If it makes you feel better, I've blown fuse 18 by plugging the compressor into the ashtray lighter outlet. Strangely enough, I did not have the same problem when plugging the same compressor into the center console outlet - so that's the one I now exclusively use when airing up.
    2006 300C SRT8 Silver Steel (Mods: Diablo Trinity w/ canned 93 octane CAI tune, Legmaker Hammer Design intake, Jet 180* thermostat)
    2008 Ford F250 4x4 ECLB Power Stroke
    2010 Ford Flex Ecoboost AWD Limited
    1996 Chevrolet Impala SS - Too many mods
    2004 Kubota L3130
    Sep 2009
    Puerto Rico
    Eric, that's exactly what happened to me. Previously and after the event I'd connected the compressor to the console outlet without problems. Only occured when connected it to the ashtray outlet. Weird, since both fuses are of the same capacity (20 amps).
    Thanks for sharing your experience with us. I'll make sure that I will never connect the air compressor to the ashtray outlet (named "Selectable Power Outlet" in the owner's manual).
    Hemi RT's Avatar
    Hemi RT is offline ?????
    Jul 2007
    Medicine Hat, Alberta
    The lighter in the ashtray isn't meant to be used as a power supply as the connections in the bottom of the plug aren't meant to carry heavy loads nor the wiring, that's why they put the power outlet in the console unless you don't have the smokers kit, then the outlet in what looks like an ashtray is a power outlet and a cigar lighter won't work in it.
    Hemi Registry #00730
    Sep 2009
    Puerto Rico
    Glad to know it. Thanks, I'm sure this info will save some headaches to owners.
