Results 1 to 4 of 4
    impala11419 is offline LX Padiwan
    Brooklyn, NY
    LeBra for 300 Limited
    Does anyone have a pic of the Lebra for the chrysler 300 limited. I was going to buy on but i need to make sure that it has the opening for the license plate. Whould anyone have a pic or know a part number for this? or if anyone knows a place that i can get a front end cover for about $100 that works too.
    Ryster is offline LX Newbie
    Jul 2004
    Quote Originally Posted by impala11419 View Post
    The LeBra part number for the 300 Limited is 55974-01.
    Not sure if it has an opening for a front license plate. Not all States require a front plate, so I can't imagine they would cut an opening for the plate as it wouldn't protect that area of the front for people with no plate.
    Now, if the LeBra doesn't cover the bottom of the grille where the front plate bracket is mounted, you may be good. You may have to remove the front plate, install the bra, and then remount the front plate.
    Not sure what bra this is, but it looks like the grille remains open allowing you to mount the front plate:
    http://www.euroticar.com/images/cata...29-thum255.jpg
    You could always order the bra from a local retailer and if you don't like the way it fits return it.
    cm2005300's Avatar
    cm2005300 is offline The New "Milli Vanilli"
    Bc
    just an fyi those do more harm than good by trapping dirt underneat and ruining ur clearcoat
    ive had nothing protecting my car and only have 2-3 chips on the front and some on my doors which those dont protect
    MOD LIST : NOT ENOUGH!!
    warnercc is offline LX Newbie
    Jun 2007
    I have had a lot of LeBra's products over the years for a lot of different types of cars and what they generally do is have an area where the license plate is outlined in a felt looking edging but the bra material intact. If you need the license plate opening, you just cut out the material inside the outline and the bra looks like it had the opening from the manufacturer. I know it's hard to imagine from my feeble attempt to describe it, but it looks and works very well.
