Results 1 to 10 of 10
Like Tree3Likes
  • 1 Post By fnkychkn
  • 1 Post By Montreal300
  • 1 Post By Cbudden
Thread: I think I'm missing something...
    Cbudden's Avatar
    Cbudden is offline LX Newbie
    Jan 2012
    Poughkeepsie, NY
    Been lurking on the message board since I bought my 06 SRT in August and I have a question I haven't been able to find a quick answer to, I was reading some other posts about a factory sub installed but I don't see one in my trunk. I'm assuming the previous owner removed the sub but how would I know if the AMP was removed as well? Where is it located? I may want to try and purchase a sub from someone and get everything back to factory specs...
    Thanks to anyone that can help this new guy out...
    Chris
    fnkychkn's Avatar
    fnkychkn is offline genuine factory cercumsized sh!tforbrain
    greasy cardboard box
    the sub for the '06 300 is mounted to the parcel shelf and not visible from the trunk or interior.
    btw, welcome to LXforums.
    Cbudden likes this.
    Cbudden's Avatar
    Jan 2012
    Poughkeepsie, NY
    Thanks for the quick response. I'll have to check tomorrow.
    MOL SRT-8's Avatar
    MOL SRT-8 is offline SHOW & PERFORMANCE
    Dec 2006
    SAN DIEGO, CA
    not all the srt's came with the rear sub. It was an option.
    Ron380's Avatar
    Ron380 is offline What do I look like, a comedian?
    Mar 2008
    Dayton, OH
    Just for clarification... what kind of car/model do you have? You might be able to get a replacement window-sticker from a dealer, using your VIN. That should tell you if there is (or is supposed to be) a subwoofer in it.
    2007 TorRed SXT/AWD: Gone, but not forgotten!
    2011 Mustang GT Premium, Kona Blue
    2007 Ram 1500 4x4
    "I reject your conjecture and substitute my actual experience."
    Cbudden's Avatar
    Jan 2012
    Poughkeepsie, NY
    I've got a 2006 300 srt. I think I've got all the option packages....I'll have to try and get my window sticker somehow.
    Largo, FL
    You want the build sheet, not the sticker. Build sheet will have EVERYTHING your car came with.
    Cbudden's Avatar
    Jan 2012
    Poughkeepsie, NY
    Is there an email address imshouldmrequest the build sheet from? I took a quick look on the Chrysler site and didn't see anything.
    Chris
    Quote Originally Posted by srt8-in-largo View Post
    Montreal300's Avatar
    Montreal300 is offline Go Faster with Class
    Sep 2009
    St. Lazare Quebec
    Do you have the REC Navigation head unit and Boston Acoustics sound system? If you do, you have the 8 speaker system which includes a center dash speaker and a rear deck mounted sub. The BA system also has an amplifer under the drivers knee bolster to the left of the steering column. An option, only for the SRT8, was a powered sub in the same location using the same wiring from the amp as the non powered sub. The only way to really tell is to drop the felt panel in the trunk under the back shelf.
    The base 6 speaker system does not have the center center dash speaker nor the sub. It doesn't have a separate amplifier under the drivers knee bolster either. I doubt you have this version because it didn't come with the steering wheel controls.
    Cbudden likes this.
    Pedator, CAI, MDS indicator, ESP/BAS defeat switch, Tranzformer, blacked out wire mesh grille, smoked and flashing side markers, 9005 2400k 65W fogs, Euro rear fogs, debadged and demolded, 255/45/20 Nitto 420's, Boss 338 wheels, painted calipers. Glovebox & cup holder LED Mod. Blastin Bob 6db reso delete pipes. Euro LED side signal repeaters, 55/35 window tint, BT catch can. Color matched tail lights. Custom front lip. LED interior lighting.
    Next: Lower with BCR Coilovers.
    Cbudden's Avatar
    Jan 2012
    Poughkeepsie, NY
    Found everything I was supposed to have (including center dash speaker). Thank you again everyone!
    fnkychkn likes this.
