I've been wanting to do this ever since I installed matching fogs in the MSRT. It took quite a while to get this all together, but last night I finally did it. Here's the scoop.
I contacted Aaron and we exchanged info about what I wanted (6000k HID H10s), and then I filled out the on-line order form, etc.
Here's how the Heritage Edition looked as I started the job (with the recently painted garage floor I might add)...
Here's how you know what you get in the DDM kit box...
Here's what half of the components in the box look like: From left to right... the HID bulb itself (including a rubber weather boot and an extra set of wires (blue & black) - the wires just pull out of the boot), the "thin" HID ballast connected permanently to the HID Ignitor, and "HID Decoder". The "HID Decoder" is the new form of the former white ceramic capacitors that used to ship with the product for anti-flicker control. This is a much better design from all appearances. Also included were some cable ties, which I did not use, and two double-sided sticky foam pieces for use in mounting the ballast to a fascia or bumper surface.
Here's a close-up of the "HID Decoders" which I took to ask Aaron and Todd Staples (Stealth Auto owner) what the heck these things were!
Continued in next post...
