it that the part hanging off my stock filter box? if so i know how if not how do i do it? also there is a thread where someone got quoted 600 for a 30,000 mile service just too funny!!
2.7 v6 by the way and sorry i meant pcv not pvc hahaha
MOD LIST : NOT ENOUGH!!
to change the 3.5 pvc vavle my dealer had to remove intake mani... not sure about tha 2.7
2.7L
The Positive Crankcase Ventilation (PCV) valve is located under the intake manifold on the right bank of the engine. 1.Loosen the hose clamp (2) from air inlet tube (1). Position the tube (1) away from the throttle body.
2.Remove the Exhaust Gas Recirculation (EGR) Valve tube, refer to (Refer to 25 - EMISSIONS CONTROL/EXHAUST GAS RECIRCULATION/TUBE - REMOVAL) .3.Remove the PCV hose (2) from valve (1).
NOTE: The upper intake manifold just needs to be loosened and position aside enough to gain access to the PCV.
4.Loosen the intake manifold bolts and position the intake manifold aside enough to gain access to the PCV valve, refer to (Refer to 9 - ENGINE/MANIFOLDS/INTAKE MANIFOLD - REMOVAL) .5.Remove PCV valve (2) from the cylinder cover (1).
thanks fnky you always come through
