Does anyone know what kind of gains you get from running stright pipes on a 5.7?? its stock sized pipe, just cut outs where cats and mufflers were with welded in filler pipes. Or am i loseing and where? Thanks for your help!![]()
Not funded by Mommy n Daddy.
I did mines before, and it felt like shi*! I wouldnt do it..
You would lean out and run worse......................................
Bob
i cut my reso's off and added straight pipes, it's not any noticeable gain or loss
When U see me in my town Everything is BLACK & RED!!!!
It's a low end torque loss. Sounds menacing though!
Thats interesting, as I have found my best MPH and ET came after I had to gut the cats when they were destroyed by an excessively rich tune. Keep in mind our cars are flowing a $hit load of air....more than any of your old school cars use to in similar heads/cam/header configurations.
Guys, back pressure or the lack of it is not what is required to build torque. What we are looking for is maximum velocity and the benefits of that velocity in regards to the scavanging effect which helps clear the cylinders of all that burnt mixture. There is probably a more technical explanation out there.....but consider this:
We use to purposely put 3 in collector extenders (sometimes up to 12 inches long) on the ends of the headers to maximize the torque curve. This effect needs to be tuned of course (typically gauged by cutting where the paint stopped burning off the extension), and then adjustments in the A/F to make for any leanness, but unless someone can show me a before/after dyno where they gained hp/tq from putting a restriction (i.e. catalyst element) in the exhaust I would chalk all the "I lost torque" inputs to seat of the pants misperceptions mostly caused by the extra noise you are undoubtedly hearing. As we all know, a quite exhaust always "feels faster".
Stupid Nasty.... 9.59 @ 148
PWR heads+FRI intake / HHP-BES Forged 6.4 / HHP Stage 4 cam / KOOKS LT / Pro Torque 2800 / Southern Hot Rod NAG1 HTCr - V-7 YSI @ 19 PSI, 200 shot N20.
Thanks, you sound like you know what your talking about! i already cut mine off last summer and i didnt think i noticed much of a difference.... just noice... and as you said the noise prolly makes it feel faster..... lol It would be nice to see someone with Dyno run test's with befor and after cut-off's.... but until then, im going to keep running em loud.... Thanks for your help!!!
i heard if you straight pipe your car and i mean only stock manifolds and cats and then run it straight piped from there that i would burn out my valves..........
when I dynoed with a stock 6.1 with longtubes and my cutouts open I lost alot 15hp ad tq down low but picked up it all back up top and gain a little 7 or 8.
Now that I have a 426 long tubes and a blower I gain any where from 40-50 hp and toqrue all the way through the band.
So I guess what I am trying to say is. they make the car sound great but unless you have a major build that is going to need to release alot of air fast the cut outs will not help you, but they will make your car sounds amazing!!!
PWR 393, Twin 6262mm Turbos, SHR trans, Fore Fuel system, Wilson Hemi Sheet Metal Manifold
880 RWHP 775 RWT at 16 psi and 17* of timing
Tuned by Robert@ Ditos motors
Walk Softly And Carry Two Big A$$ Turbos!!!
