So, it is a good news bad news situation. First the good news. With the software upgrade i get the cruise on and cruise set notifications on the evic. Nice little feature. Now for the bad news. Some of the features in the diagnostic mode no longer work. Oil pressure, pedal position are two important ones that come to mind. Second the engine coolant temperature no longer works. May have been assigned a new address with the 2006's so the cluster no longer sees it. It is not only the engine temp in the diagnostic mode that is messed up but the temp guage on the panel that doesn't work. I will just have to reflash to an older version tomorrow. Not a big deal since I have figured out how to fool starscan into sending the file even if it is an older version. I will probably try one of the many other files for the ccn to see what features I can get enabled. I will post more tomorrow.
2005 Dodge Magnum R/T
-Martin Luther King, Jr.
