Is this possible? Does the rear bumper need to be changed or are there kits that will work? This is for a friend of mine who wants a set of Magnaflows. Thanks for the help
Yes sir it is possible,there is a mopar bezel kit that will have the necessary instructions on how to cut the bumper out for the second opening(and first assuming that all 300 have a downward exhaust tip)...
Smokin Tail Pipes!!!! and there are quite a few others on the forum with similar setups.
ODD
06 SXT AWD Silver Steele Metallic: Debadged, Demolded, Tinted Front Windows, AFE Stage II, Borla 125 Catback, Air Silencer Delete, Cross Drilled Rotors, Diablo Predator,Hood Shocks, Strut Caps, 6000k LowBeam & Foglight HID's, Lowered on BCR Coil-overs. Mopar Remote Start, Charger Chin Spoiler, Led Tails, and crazy nut behind the wheel...
do you have the link to the bezel kit? I think this might work
Before I picked up an 07’ 300C I had an 05’ 300 Touring that I put dual exhaust on. I put on a Magnaflow setup however the exhaust drone was really loud so I had a shop put in a pipe to cross the two exhaust pipes to help bring the drone down. Basically I made an H-pipe setup. I did have the tips turned slightly down and because the 3.5L doesn’t have a stock exhaust hump/hole for single exhuast anyway you don’t have to worry about cutting a second hole in your bumper…...at least the bumper was flush on an 05’.
I read a post here about 3.5 and dual does not buy any performance gains, it's a sound/like thing only. Don't know how true it is.
you can do 2 things, the place where your doing it have them cut another one into your bumper or, what i did was when i did dual exhaust for my 3.5 magnum i just bought an srt8 rear bumper had it painted silver steel metallic and it fit perfectly with dual cutouts. never had a problem. you may wanna check craigslist you can find it really cheap. my buddy gave me his(black one) for free because he was doing a custom kit on his srt8.
MODS: K&N Filter,SRT8 Rear bumper swap, Flowsmaster 40 series dual exhaust w/y-pipes,
Dual 4 inch chrome rolled tips, SilverStar headlights-highbeams-and fog lamps. -PROJECT REGAL UNDERWAY!!!
2006 Magnum SXT (daily driver)
1987 Buick Grand National
making a ten second pass in a honda is like coming out of the closet-you may surprise alot of people, but in the end youre still gay.
VTEC all the effects of turbo lag, but none of the horse power.
VTEC= Virtually Torqueless Economy Car.
VTEC= Very Tall Engine Coolant.
I used the Mopar duel set up which comes with the pattern to cut out the left side. Simple to do. It's the mag SXT on the left.
http://i30.photobucket.com/albums/c3...Picture012.jpg
415 rwhp 420 rwtq 5.7
536 rwhp 621 rwtq on spray
Thanks to RT6 Motorsports & PowerPortedPerformance
11.306 at 122.59 at Z-MAX
PPP stage III heads
PPP BIG cam
PPP underdrive pully
3200 stall converter
Arrington 90mm throttle body
other stuff.....
