Originally Posted by
Dodger
OK..I deleted my paired device with uconnect. I turned the unit off, took out the battery. I have repaired the blackberry to my uconnect. Pairing was fine.
The phone worked great until I turned my car off. I left the boothtooth on - on the blackberry. Upon restarted the car this is were the unit doesn't connect at this point. I get screen errors on the blackberry - disconnected from uconnect - Waiting for uconnect - Would you like to connect with uconnect- yes or no. The last question flashes for about 2 seconds and then is gone. It will keep doing this, until I turn off the bluetooth. I can select yes but it doesn't respond it just keeps on popping up and then it gone.
I don't think this is my uconnect because my v3 is not having problems.
Nightshade maybe if you read this before your Friday meeting with RIM folks what my errors are.
Thanks
