Results 1 to 8 of 8
    Mar 2009
    Vancouver,BC
    auto seat not working
    anyone have problems with autoseat randomly messin up on them???
    what should i be looking at to fix this problem?? i tried turning it off and on from the evic but that did not help?? it just doesnt work anymore!!!!
    Mar 2009
    Vancouver,BC
    anyone??
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    i guess we need more insight as to what is messing up..
    is it not sliding back on exit?
    does the memory not return when you hit the button?
    does the memory not return when you unlock the door?
    if it is not sliding back, recalibrate it:
    slide it all the way forward, then all the way back, then all the way forward again..
    if the memory button doesn't work, might be a bad module or a broken wire
    if the memory from the key doesn't work, reprogram the key (see your owners manual)
    Mar 2009
    Vancouver,BC
    it does not slide back on exit.. i liked that feature and now it doesnt work!! i was so used to it..lol..
    Apr 2006
    per above:
    Quote Originally Posted by Mr. iNCREDIBLE View Post
    also remember, it will not slide back if the seat is forward LESS than 2 inches from completely back..
    that is if the seat is all the way back, and doesn't have 2 inches of moving room for the slide back to exit feature, it won't slide back..
    make sense?
    Mar 2009
    Vancouver,BC
    per above:
    make sense?
    This is not the case...seat is n ot all the way back...Could it be possible something got unplugged?,. I had a look but the harness seemed to be connected...
    Apr 2006
    did you recalibrate it?
    seat doesn't have to be all the way back, but if it is less than 2 inches from the full back position the slide back won't function..
    try running it all the way forward with motor running, then remove the key and open the door see if it works
    AFTER you recalibrate the setting per above.
    Mar 2009
    Vancouver,BC
    lol.. i guess it just needed to be recalibrated...it works now.. thnx!!!!
