    mikestyle is offline LX Newbie
    Feb 2006
    Smile Amp and woofer installation
    Hey guys i have a mono Kenwood 1000w amp which will be running 2 woofers. i have the Boston Acustic sound system (the system with the stock subwoofer). is it possible to tap into the stock subwoofer and run wires to my kenwood amp?
    i have posted this on 300cforums 40 views but no reply, so i decided to join this forum
    Todd RT's Avatar
    Todd RT is offline 05 Cool Vanilla Magnum RT
    Tampa Bay FL
    Easy, you mus thave a 300C if you have a stock Sub, huh? Unless it's a Kicker Sub.
    Anyways, you've already got speaker level, low level audio at your rear deck going into the existing sub, just run it to your amp (assuming it has speaker level inputs). Or if needed, run it through a 'Line Output Converter' to lower the 'speaker level' output to 'line output' level, into your amp. There just so happens to be power in the rear too.
    I'm about to do the same thing, but don't have a factory sub in the Magnum. Gotta run it off the front door speakers.
    There is a product coming out from peripheral that will allow you to 'add an amp' easy, but doesn't sound to me like you need it.
    Here's a few threads to read if ya want:
    http://www.300cforums.com/forums/car...-upgrades.html
    NEW! Ipod, aux input, steering wheel controls, vss wire, etc
    05 "Shagwagon" R/T
    Go USF Bulls!
    Hemi Registry #000514
    Feb 2006
    Thumbs up
    Yes i do have a 300c, and thanks for clearing things up for me.
