    fishinboy23's Avatar
    fishinboy23 is offline LX Padiwan
    Jan 2009
    300 srt8 windsheild nozel on bumber question
    On the srt-8 they have those nozels right in front of the headlight. I cant keep it down, its always popped up, and I dont know how they work. If i spray my washer fluid it only sprays the windshield. Any idea on both problems?
    RIDEW/ME is offline LX Newbie
    Nov 2007
    West Michigan
    Check this out...
    Had the same thoughts when I first brought home the SRT. Best advice would be to consult the owners manual. This worked for me!!! I think the headlight washers only work in certain situations.... like headlights on and washer jets fired.... Simply asking the SRT for washer fluid isn't enough... hope this helps...
    As for the fit and finish of the bumper jets... can't help you. Accident perhaps??? Some elbow grease should be enough to eliminate that problem... You can do it!!!
    Chrysless25's Avatar
    Chrysless25 is offline LX Padiwan
    Jan 2009
    new orleans
    Quote Originally Posted by fishinboy23 View Post
    I bought some double sided 3M tape , red kind and cut off small pieces same shape and put underneath washer nozzles and installed it back on. I don't think it will come off now that stuff is pretty strong same tape they use on lip spoilers!
