Results 1 to 15 of 20
    BobFam's Avatar
    BobFam is offline LX Newbie
    2008 300C SRT8 EVIC-Oil Change Required?
    I have a 2008 300C SRT8. I have 2,800 miles on it and the EVIC is showing a message "Oil Change Required- Contact Dealer". I don't see any message like that in the Owners Manual. I see that the recommended oil change interval is 3,000 miles for heavy duty service (short trips, stop/start driving) and 6,000 miles for regular duty. Can anyone explain the message and why it came on at 2,800 miles? Thanks, regards, Bob.
    2008 300C SRT8
    With all available options. My installed addons:VES lid and seat belt pads by Jina's Simple Sew, Weathertec front side window deflectors
    jd8486's Avatar
    jd8486 is offline "Redline Durant"
    Feb 2008
    Oregon City, Oregon
    I have a 2008 SRT8 Charger and it came on also. I believe the computer sets it to come on at certain intervals. I changed the oil myself for 1/3 what the dealer wanted and reset the message myself.
    BobFam's Avatar
    Hi. OK. Thanks. The Tech at my dealer said it comes on from a "Viscosity Sensor" which I did not believe. What mileage did yours come on at? How did you reset it? He reset it by turning the key on and pressing and releasing the gas pedal three times in 10 sec. and turning it off. Then when the engine was started it was gone. Regards, Bob.
    2008 300C SRT8
    Kenny Pollock's Avatar
    Kenny Pollock is offline '06 Charger R/T
    Jan 2008
    Hollywood, FL
    Yep, that's the procedure: Ignition switch on (don't start the engine), gas pedal to floor 3 times, switch off.
    dhounsell is offline LX Newbie
    Nov 2007
    first oil change is correct at the mileage
    will come on at plus 6000 miles
    BobFam's Avatar
    Quote Originally Posted by dhounsell View Post
    Hi. Why did it come on at 2,800 miles? Regards, Bob.
    2008 300C SRT8
    Nov 2007
    not sure but it went 6000 the next time, Dealer does free first oil change so I did not question Doug NH
    BobFam's Avatar
    Hi Doug. OK. Thanks, regards, Bob.
    2008 300C SRT8
    bandaid is online now The "Black Pearl" is going to SF7
    Edmonton
    Quote Originally Posted by BobFam View Post
    Advance notice, Chrysler expects you to book an appointment for two hundred miles from the time of the message.
    BobFam's Avatar
    Hi Bandaid. OK. Thanks. Regards, Bob.
    2008 300C SRT8
    karfreek's Avatar
    karfreek is offline LX Guru
    May 2006
    Fultonville NY (Upstate)
    Most car people and engine builders suggest changing the oil at 1/2 the interval the first time. So, since the normal interval is 6,000 it said 3,000 for the first one. It gave you 200mi notice.
    Is the service oil light on the 2008s controled by an algarithym or is it just a mileage count down timer?
    From what I have read GM perfected the algarythm back in the late 80's early 90s that takes into account engine temp, ambient temp, Throttle position, engine RPM and then calculates oil life. Honda then bought the rights to this to use in their cars.
    Jay
    2011 Dodge Challenger R/T Classic - Redline 3-Coat Pearl, 6-speed
    2005 Dodge Magnum RT-Can you say...HEMI?
    2004 Chrysler Pacifica AWD-Everything but the kitchen sink.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    If you have NAV, you can go into the menu settings and change the mileage requirements as well as reset it.
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    I bet if you turn on the ignition and press the gas pedal to the floor 6 times in 10 seconds the interval will be 6000 miles
    Tbird100636's Avatar
    Braintree, Massachusetts
    Exclamation
    No viscosity sensor, read my next reply.
    www.ramtruckforums.com
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    Quote Originally Posted by Cam View Post
    2008's have a auto feature Cam, not the set it yourself one we have..
