has anyone tried to use any interior parts or pieces off an an 08 into an 06 car. i really want a totally dark interior. what do you guys think??? any ideas. anyone tried it yet??
andre
andre
Haven't heard of anyone trying it yet but I'm with you. I want the all black interior too!!
maybe try som vinyl dye? works great for all plastic
Sounds good to me!
i have abuddy who has all black in his.... he did the interior swap.... he has an 07 with 08 interior
also us charger guys can swap out 06 interior for the 08 super be interior so im sure its possible
so he has a 300 and did this or a charger
Are there any pics? Did he do the dash too?
I just put the 2008 Black door panels and trim on my 2005 300C
I have a few parts to finish, the knee bolster under the steering wheel, I need to swap to a 2007/2009 push on/ push off parking brake before I can install that part..
I have the glove box, I need to swap the key, and the far end of the dash by the glove box that is the tan color, I'm going to either dye it dark slate or have it wrapped in pleather, not sure yet..
2008 door panels:
and some black lower trim panels:
Where did you get those? Midnight auto supply? Is the ebake a direct bolt on?
member on 3CF had them, he wrecked his 2006 SRT, bought a 2008, liked the 2006 interior better so we swapped..
yes the e-brake is a direct bolt up.. just got mine today from www.moparpartz.com $57 shipped.. looks exactly as the mine with the pull cable, minus the pull cable..
Adding some pics of my conversion. These will shed some light on how to mod the front doors to accept the 08-10 panels. I will try to explain the pictures. I installed the 2010 bracket with the lower bolt. I set it roughly in place and tightened the bolt so the bracket was solid but could still be moved by hand. I then removed the switch assembly from the door panel. I mocked up the door panel and installed the clips and screws. Once this is done you can look through the door panel hole (behind the door pull) to the bracket and see if the bracket is properly lined up. Make any adjustments through the switch panel hole. Once aligned, carefully remove the door panel so as not to disturb the bracket alignment. Now, trace the outline of the bracket with a pencil. Make your cuts as I did. I got mine on the first shot with no corrections. Also pictured is how I secured the the memory module. This caused no interference. The rear panels need to be screwed and clipped in the original locations. The screw for the pull needs to be drilled into the 05-07 bracket. While I was doing this I added the proper wiring to illuminate the the LED map pocket lights. I ran wiring from the light switch illumination circuit on the left side and from a connector at the A-pillar on the right side. Pain in the ass, but worth the trouble. All 4 pocket LED's light when the lamps come on now. Added a pic of what connectors I used for the LED's
Hi
So the 08-10 door panels will fit a 07 300C? Its only your mod necessary to make it work? clips all match up?
Thanks
Catchcan,22Elite,DNX9260,DVD HR,Alpines,amp,StarTech,07-3.0CRD,314BHP-645 N/Tq,spoliers,Mesh Grill,GB roof,Kluck fenders,Passport 9500ci,Paddle shifters,6K HID,HL,FL,BU,Pillar POD,tracker,3" SS pipes no mufflers,Razor Edge,Remote Start,belly lights,LSD,Pedder,20" w/nitto,sway bars, CelticTuning remap,Lg intercooler,Tq limiter off, VIS SRT hood,GripTuning,Volant,6K LED HALOS,HL,FL,Aeroforces,REM R Brace,tranZformer,F&B Cam.VIP300,LXCustomSolutions,StopTech,No ESP
All clips and screws around outer edge are same. You need to order the 08-10 door pull bracket and modify door as I illustrated. Also, depending on trim level, certain panels have the led map pocket illumination. If you want them to work you will need to run additional wires. The rear door panels retain the 05-07 pull brackets but need a hole drilled in them for the pull screw (doesn't line up exactly).
