For Sale...
Richmond Gear ring and pinion set for 210mm Automatic Rear Ends 3.55 ratio. Est of 12k miles on the set. Changed setup. $350. If u like for me to ship, $400.IMG027.jpg
If this will work with my 2005 CSRT8 consider it sold and send me your PayPal if she fits!
Visual Mods: Vis Racing cf ram air hood, Grip deep dish, IPC tail lights, Billet Wing, 22" D'vinci Attivos, Flashtech 6000k Halo's, Stock Tint, SRT Aluminum Pedals, SRT Engraved Shifter Plate.
Sound Mods: Alpine 7" Touch Screen, JL Audio 1000/1 Amp, 2 JL Audio 12w6v2's.
Performance Mods: SMS Supercharger with 74mm pulley, 100mm Arrington TB, LMI custom True Cold Air Intake, 80lbs Injectors, Fri Tomahawk Cam, Custom Catless Mids, Blastin Bobs 9Db Reso Delete, and always looking for New/ Better Tires. Tuned by Diablotoona!
9.6 PSI
SRT8 are 215mm If i'm not mistaken. This would be for the 5.7 guys.
Drag Racing The Family SedanGoin' Fast With Class
If this was for the 215 rear end I would have scooped them up
EXTREME XENON-Your #1 HID Source
Chrysler 300C 2006
PWR Mean Street Heads-PWR Cam-6.1 Intake Manifold-Custom Push Rods
ZEX Nitrous Kit-LMI Air Intake-6.1 Differential/Drive Shaft-JBA Headers/Hi Flow Cats
6.1 Oil Pump-OSTMIKE Custom Tune-All Labor Done By AHMP
http://www.lxforums.com/board/f58/**...ble***-312661/
Roy.
Retired Navy.
2006 Black 300C SRT8 with option Groups I & II, Sunroof, Rear DVD
Added Goodies PPP 426 Stroker and Ported Heads, FRI Ported/Coated Intake, Diablo CMR tuned, MPTCM, Magnaflow catback, SHR Transmission, DSS 1000 HP axles, Quaife LSD, KW V2 Suspension, Hotchkis swaybars
Thnx srt8 guys. This r/t came with the shaker hood, so i didnt go with the 6.1. There's a lonely 5.7 out there somewhere.
Is this everything that is needed for install into a 5.7?? I've got a 2010 RT that could sure use some gear help!!!!
ORT-2 - 2010 Charger RT
Mods: TruFiber SRT Hood, Eibach Pro Lowering Springs, Predator - DiabloToona, Frankentake, DMH Cut-Outs, Debadged and Demolded, SRT Grill with Inserts, Chin Spoiler, Rear Diffuser, 20% tint, Daytona Blue Racing Stripes
I got a 215mm- 306 set up with everything if ud wanna swap + alittle $. Im located in n.j
I've already upgraded so I dont need to swap.
The question on the 2010. I know it works for 06-09. The cars changed in 2010 so not sure if it will work.
this is just the gears? or is it loaded in a 210mm diff?
Interested in the setup. I'm assuming it fits a 06 300C? Also, does the 210mm diff come with?
I also have the diff. Make offer for all three.
Someone buy these up. Would like to upgrade with a body kit.
What else would I need to install in my 06 5.7? Approximate install cost?
It cost me 300 plus gear oil.
