THIS IS THE COMPLETE SETUP. THIS INCLUDES ALL THE NESSICARY PARTS TO HAVE THE VEHICLE RUN EXCEPT FOR THE TUNE. THE BLOWER, BRACKETS, PULLY, BELT, PIPING, LINES, BRACKETS, ALUMINUM COLANT TANK, COOLERS, AUX COOLER PUMP, ECT. IS INCLUDED. THIS KIT ALSO INCLUDES SRT4 52LB (STAGE 1) INJECTORS WITH LESS THAN 50 MILES ON THEM ($500 A MONTH AGO). Included also is a Diablo I1000 touch screen predator. A 2 bar map sensor is included that is new. The kit began as a GS motorsports supecharger and I eliminated the piggy back and replaced it with the srt4 injectors for a cleaner system. The system has 4000 miles. Price is $3200+ shipping.
What are you using for a FMIC? Pictures would be neat..
^^^ Need some pictures
MIKE'S
TOP BANANA 3949 (SMOKE'N) 6.1 w/forged pistons, Forged push rods, BB Stage 2 Valve body, Ported Eagle Heads, PWR Cam 219/230 593/578 114LSA, N2O, Ported Thottle Body 85MM, 3200 Stall PRO TORQUE, AND SOME UP GRADES TO THE TRANSMISSON, UPGRADED REAR AXLES, Tranzformer, Paxton Novi 1500 Supercharger 9psi. ETC ETC
[IMG]
[/IMG]
pictures!
Bump
I am here: http://tapatalk.com/map.php?ajmujv
Pictures will be up this evening. Thank you
Would this fit an 08 Road & Track Charger? If not, I have a 6.1 plenum, fuel rails, and throttle body sitting in the garage...would that make it work?
If you have any other questions or need more questions please let me know.
Killah I am not sure maybe someone can chime in. Thank you
yes, this will work with your current 5.7 set up. depending on the size of the blower pulley, you will see 6 - 8 psi. solid kit and will work even better with a air/air intercooler instead of the gsm set up shown in the pics. that air/water system that gsm provided with these kits was VEEEEERY restrictive. i picked up 80 rwhp by just changing to a air/air intercooler.
Procharger Air/Air HO mated with a Paxton!!!
dyno results after the swap toi air/air
Legmaker dyno results w/ procharger air/air on paxton blower
the above kit is a good start for someone looking to do a solid blower kit for a street car. mine has been very good to me. simple, efficient, and reliable. this kit even has the preferred air inlet tube and coolant tank.
Thank you very much for all the information!!!
Does this come with a FMIC and do you have a picture of it?
looks like just the air/water kit from the pics..........
^^^ yea that what I'm thinking..
