Results 1 to 9 of 9
    fasthemiram05's Avatar
    fasthemiram05 is offline LX Padiwan
    Oct 2010
    Orlando
    Big Injectors...
    I've got a full set of 8 Siemens 60# injectors... That's at 43psi... Hemis run 58psi. Not sure of the exact calc on that. But they should be in the range of 70-80# injectors.
    Here is some info....
    P/N 108191
    Use for modern super street or racing 8 cylinder applications that use the U.S. CAR, EV6 wiring harness. Body Design: Pencil, composite plastic Flow rates: 635cc/min, 60lbs/hr at 43.5 psi (3 bar) (This injector will work with all factory injector drivers) Length: 3 inches, 74 mm Diameter: 19 mm Part number available: 108191 - Long U.S. CAR electrical connector Resistance: 16.5 Ohms, saturated, high resistance Orings: Top and bottom, 14.5 mm -Viton Fuel rating: Gasoline, E10, E85, Methanol
    Looking for 350.00 shipped as they are 500.00+ New.
    Sold 2011 Hemi Express
    12.41 @ 110
    http://www.youtube.com/watch?v=BA_UAWbGYZE
    Modern Performance Engineering
    New Project:
    2012 Ram Express
    Ripp Supercharged
    Oct 2010
    Orlando
    they are 80# injectors
    str8 pwr's Avatar
    str8 pwr is online now Better to be lucky then good sometimes
    Jun 2011
    kitchener, canada
    !!!!! I paid 625.00 and that was the cheapest within the province!!
    Fantastic price GLWS
    Visual Mods: Vis Racing cf ram air hood, Grip deep dish, IPC tail lights, Billet Wing, 22" D'vinci Attivos, Flashtech 6000k Halo's, Stock Tint, SRT Aluminum Pedals, SRT Engraved Shifter Plate.
    Sound Mods: Alpine 7" Touch Screen, JL Audio 1000/1 Amp, 2 JL Audio 12w6v2's.
    Performance Mods: SMS Supercharger with 74mm pulley, 100mm Arrington TB, LMI custom True Cold Air Intake, 80lbs Injectors, Fri Tomahawk Cam, Custom Catless Mids, Blastin Bobs 9Db Reso Delete, and always looking for New/ Better Tires. Tuned by Diablotoona!
    9.6 PSI
    Oct 2010
    Orlando
    Oct 2010
    Orlando
    Oct 2010
    Orlando
    Oct 2010
    Orlando
    Oct 2010
    Orlando
    mattechperf's Avatar
    mattechperf is offline LX Newbie
    Nov 2008
    Phoenix
    PM sent
