Where's my AVATAR?
Note:
I have enabled avatar uploading. So if you would like to upload an avatar, just go to your profile and scroll don to the avatar control panel. You can upload an image from there.
Remember, avatars are limited to 80 X 80 pixels or 6kb
Because there are no restrictions on how large a "linked" avatar can be (darn phpbb!), I had to disable them. But, who needs them? Just upload your favorite avatar and use the built in feature. So, if you had a "linked" avatar it will not show up now. See the directions above to upload it to the forum directory.
If you need an avatar "dumbed down" I recommend photoshop or other graphic programs. Simply resize the image to 80X80. If the image is still over the size limit, bring down the resolution a bit until you are under the limit.
Thanks!
- You may not post replies
- You may not edit your posts
Forum Rules
