Results 1 to 15 of 16
    OSTMIKE's Avatar
    OSTMIKE is offline EFI Tuner
    Jul 2010
    North of Pittsburgh Pa.
    Can someone show me how to post an Excel spreadsheet or Excel Table
    I don't want to add an attachment, I want the sheet to show in the thread. I can upload it to Photobucket as an image then link it in but really want to be able to update a spreadsheet often and keep the actual sheet in the original thread.
    Can anyone give me some pointers?
    Thanks!
    Specializing in Gen III Hemi Tuning
    Mustang Chassis Dyno
    Diablosport CMR Dealer
    Lowest prices on Trinity's
    E85 Tuning and conversions
    Tuning: FastXFI, BigStuff3, HPTuners, CMR, CromePro,Hondata
    www.OSTdyno.com
    Email: Mike@ostdyno.com
    IES99's Avatar
    IES99 is offline IES99
    Charleston, South Carolina
    Dos Equis. I Like Beer
    It isn't easy being GREEN
    OSTMIKE's Avatar
    Jul 2010
    Does anyone know how to insert either an excel spreadsheet or excel table into a thread?
    I'm trying but....
    OSTMIKE's Avatar
    Jul 2010
    Quote Originally Posted by IES99 View Post
    I prefer IPA's
    6Shooter's Avatar
    6Shooter is offline Common as Muck ... :)
    Apr 2009
    Toronto, Ontario, Canada
    Quote Originally Posted by OSTMIKE View Post
    I'm trying but....
    I think the administrators of the board here would have to allow .xls extensions in the vbulletin extension manager so that your spreadsheet can be uploaded. You could try and convert the .xls to .html and and try a copy paste, but that opens the door for a lot of security issues, so that's probably disallowed as well.
    I think I know what you're after and it could be a good idea to tabulate type of mods on member rides so one can easily find out if something works rather than endles searching for threads ...
    I"d PM one of the mods and get a definitive answer ...
    Mopar 11 #87 of 131 in Canada
    Magnaflow Catback, BC Racing Coilovers, Mopar CAI, Mopar Lip,
    LLumar Pinnacle® Series Tint 15% all around
    If you have a Mopar '11, click here --> Mopar Tracking Thread
    FleshWound's Avatar
    FleshWound is offline Putting on the Foil
    Jan 2007
    Isle of Lucy
    not the proper way but you can take a sreen shot (PrtScn) and paste it in the Paint prog,save as a .JPG upload to Photobucket (or similar host site) and then add it here like a regular photo.
    Threegpsi's Avatar
    Threegpsi is offline Custom Fabricator
    Jul 2009
    Southern GA
    Select the area from the excel file you want to copy.... (Right click upper left cell, then drag to lower left cell. Right click on highlighted area, select copy.
    Open Microsoft Paint, Click "Edit" then select "Paste"
    Size the area to fill the whit space, save file then upload to photobucket.
    1(855) 3GC-Parts
    Gussets, Trophies, WineRacks and Metal Artwork
    You Dream It, We Can Build It
    netnathan's Avatar
    netnathan is offline Not the Momma
    Corona, CA
    Yep..
    Just highlight cells, copy, and then paste into Paint. Then you can save as .jpg, .gif or .bmp.
    2006 Charger SRT8
    BES/HHP Stage II Heads/Cam/Intake/BBK 85mm TB, NoESP TranZformer
    Hotchkis sways and BFGoodrich 275/40/20 Sport Comp-2 paws
    Predator + CMR = "Custom Dyno/Street Tuned PCM"
    err's Avatar
    err
    err is offline LX Padiwan
    Aug 2010
    I think I found a way. You'll need to create a G-mail account so you can use google docs. Then you can import the excel spreadsheet and set the file so that anyone with that link can view the file.
    For example:
    https://spreadsheets.google.com/ccc?...thkey=COTs0uAP
    Here are instructions for setting up the sharing: http://docs.google.com/support/bin/a...44&topic=28194
    OSTMIKE's Avatar
    Jul 2010
    Thanks for the suggestions. However, as I mentioned I am trying to avoid the process of:
    1. screen printing,
    2. saving to paint,
    3. uploading to Photobucket,
    4. then linking in the screen shot.
    I am trying to create a "dynamic" table that will most likely be modified many times each week. I also would like viewers to be able to view the table/spreadsheet instantly and not have to open an attachment (similar to what you would see in an inserted photobucket screen shot).
    I have also tried to save the spreadsheet as html and link it here but that didn't work.
    I can save a spreadsheet as a .pdf and upload the .pdf from my PC and link it into a post like this:
    This is weak...
    Attached Files Attached Files
    OSTMIKE's Avatar
    Jul 2010
    Quote Originally Posted by err View Post
    For example:
    This is getting closer to what I'm trying to do! If I could just have the sheet open in the post it rather than having someone go to the link it would be what I'm looking for.
    I also see "Table" tags in the option for inserting into a post. Does anyone know what these are for?
    Thanks!
    6Shooter's Avatar
    Apr 2009
    For example:
    That's pretty good - can you make the spreadsheet updatable by anyone ? (i'll go read the instructions later on tonight - probably in there as well)
    netnathan's Avatar
    Corona, CA
    You can post an active Excel spreadsheet to the Internet.
    http://www.brighthub.com/computing/w...les/21435.aspx
    But for others to edit it, they may also need Excel (licencing issues).
    More choices...
    http://www.google.com/search?source=...cf963e1097ce14
    Sent from NS1Droid using Tapatalk Pro.
    Big Bruin's Avatar
    Big Bruin is offline Sea Bass
    Dec 2006
    North Jersey
    Most forums don't (and shouldn't) allow Excel files and other file types to be attached due to security risks.
    OSTMIKE's Avatar
    Jul 2010
    Just to clarify... I don't want an active Excel sheet on the forum.
    I want to post the results,output, screen print etc. with out having to do the screen print, Paint, Photobucket, update link routine every time I make an update. I do want the output to appear as below (or similar to this): BTW - there are "table tags" on the same line as the "insert image, insert email link, insert YouTube tags, etc." Maybe this will work?
    Here's what I want folks to be able to see when they come to this thread:
    Quote Originally Posted by Threegpsi View Post
