Results 1 to 8 of 8
    bsuave's Avatar
    bsuave is offline DO it! DO IT!! I dare ya..Ahh
    Houston, TX
    2007 Jeep SRT8 overheating!!!!! Help
    Like title says, I have a friend who says Jeep overheats , any ideas????
    '10 STONE WHT CHARGER R/T MODS: 93 OCT Diablo Tune, SLP LM-II, 22" BZO Blk & Chrome 22 X 9 & 22 X10, AFE Stage II, C Can-thnigamabob.
    Current Mod #'s | 353HP/388TQ |
    COMP 274 VVT CAM, HHP Kooks 1-3/4 LT's, Tune by Mike@OST, and install by OsO@THOH coming REALLLL SOOON!!!!(APRIL-MAYish 2013)
    SpaceCity LX Modern Mopar | Graphic-Guy
    Destine to be THE fastest Stone White in a 5 mile radius!
    Srt_Driver's Avatar
    Srt_Driver is offline LX Guru
    Apr 2010
    Chicago,IL
    Check coolant,if thats fine,replace t stat
    Sent from my DROID4 using Tapatalk
    *New for 2013: PWR Heads,GTP S3 Ported Manifold,90mm TB*,Tuned,Slammed
    bsuave's Avatar
    Houston, TX
    He replaced tstat and drove around and said still running hot! He did say that he found that the hose had come off. Also he can't see the cooling fans, but does jeep have one fan or two like our LX cars?
    Srt_Driver's Avatar
    Apr 2010
    Chicago,IL
    Is his hs speeds working?check the fan relay switchs
    Rose City GC SRT8's Avatar
    Rose City GC SRT8 is offline LX Padiwan
    Aug 2010
    Portland, Oregon
    We need more info here. Heater hose blow-offs are somewhat common, especially if the radiator cap has been changed. Is that what happened? If fan relays are not working, then that could cause overheating that could cause an overpressure and hose blow-off. Relays cab be bypassed to test for proper fan operation and diagnose the issue.
    DAVE -- 2007 Grand Cherokee SRT8: Mopar exhaust, Volant CAI, DCX Depot CMR tune, BT catch can, BWoody springs and end links, Jeepin by AL upper control arms
    Can you hyperground the leads to the mason jar and get even more torque and hp?
    ekaz is offline back in black
    Jun 2006
    CHICAGO
    What's running hot? The Jeeps normally run around 215*. There is only 1 fan, if it's getting that hot, you should easily hear it running. The connection for the fan is on the driver side near the bottom of the fan shroud; I highly doubt it became disconnected, but you can check it. If the hose did pop off, there is a good chance there is air in the system.
    Unlawful Gathering
    Click for details!
    2012 300SRT
    2009 MBP GCSRT8
    Powered by PWR
    Shifted by SHR
    Tooned by Johan
    Blinged by Billet Technologies
    GlobeWarmer's Avatar
    GlobeWarmer is offline Got Gas Money?
    Sep 2011
    Phoenix
    I agree, probably air in the system if the elbow blew off - but that should clear up after a few days of driving. If not that, probably HS fan relay. Went through the same thing last summer. Replaced the radiator, fan assembly, upper and lower hoses, swapped from Motorad to Jet t-stat, reverted back to stock radiator cap (recommended)...finally checked the HS fan relay...$700 later, it was a $7 fix.
    - Taylor
    2006 Jeep Grand Cherokee SRT8
    Inertia 426 - Ported & Polished Heads - 230/234 Cam - Stainless Works Headers - FTI 3800
    Paramount Performance NAG1 - Custom 3" Exhaust w/ Cutouts - BWoody CAI
    Composed by Johan
    bsuave's Avatar
    Houston, TX
    Thanks guys for all your help. Before I could post more information for y'all, the post saved the day!! He changed the relay and burped the cooling system and everything returned to normal temps. All is well!!! Now I can try and run his a$$ down hahahaha!!! LXF is the best.
    Thanks
