Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Like Tree4Likes
Thread: **Need Emissions Help In CT. Jeep with 440 and Kooks needs inspection**
    junior666@TTCreations's Avatar
    junior666@TTCreations is offline Home of the 1191hp Jeep!!
    Dec 2008
    li ny
    Like the title says I need help getting a customer to pass inspection in CT With Kooks Headers and
    a 440.
    Chris Hull
    (516) 532-6662
    All LX/LC SRT and RT welcome
    SRT8_in_CT's Avatar
    SRT8_in_CT is online now If you ain't first you're last
    Jul 2008
    Connecticut
    Does it have any cats on it ??? The place I went to last time stuck a mirror under the car to do a visual.. If it does and doesn't throw any codes he's good for 2 years..
    Arrington Forged 6.1​..ported 5.7 Eagles..HHP Ported Intake
    227/235 cam..Paramount Trans..Dominator..RPM Roll Bar
    Nitrous Outlet..DSS driveshaft..CTP DSL..'09 Getrag 3.06
    Kooks..Corsa..LMI 4"..ATI 13% UD pulley..Billet Tech..BFNY
    11.65@117.3 w/1.61 60' NA--10.68@126.23 w/1.51 60' N20
    Dec 2008
    li ny
    He has high flow cats, may still be throwing codes
    SRT8_in_CT's Avatar
    Jul 2008
    Connecticut
    Quote Originally Posted by junior666@TTCreations View Post
    I've got them too, and my rear O2 sensors are turned off ... Funny I'm not throwing any codes now, but when talking with AJ I think we have to turn them back on for emissions.. I have to go next month.. Wish I could be of some use.. Good luck, I'll be watching this one...
    MagnumRT05's Avatar
    MagnumRT05 is offline ***Drop Beats, Not Bombs***
    Jan 2007
    Westlake, Ohio
    Not sure if CT is different from OH, but dont you have the "spend $XXX amount" and get a waiver (read: pass)? Also, does CT give you the option to take the sniffer/roller test if all the readiness monitors arent ready yet? If so, just take the roller test and pass or fail. If you fail, make up receipts for work done, ie fuel pump, injectors, etc and get the passing waiver.
    Edit: just looked and it looks like its $787 for the Cost Waiver. Wow, and I felt bad about OH and $300!
    '05 Magnum RT: 392 Twin TC70 Turbo Build
    Dec 2008
    li ny
    He had a stored code that caused him to fail. He is going to try again with the code wiped out and no CEL.
    Tbird100636's Avatar
    Tbird100636 is offline Master ASE Certified Chrysler Technician
    Braintree, Massachusetts
    Exclamation
    Um, if it's anything like MA, and it's a plug-in only test, clearing the codes resets the OBDII monitors. Not ready monitors, no pass. MA allows only 1 not ready monitor for 2002 and newer cars. Not sure what CT has for an emission test.
    BIGDAVE is offline Im a BILLET SLUT
    Feb 2006
    CONN
    Quote Originally Posted by Tbird100636 View Post
    Its a plug in in CT and I think its 2 trys.It has to be ready if not wont pass.
    05 Magnum R/T RWD inferno red
    Franks racing Sidewinder cam w/SRT springs
    Flowmaster super 40s w/custom tails
    SRT headers and Cats
    PRO-TORQ 2800rpm STALL CONVERTER
    for converter call (203)969-2886
    SRT8_in_CT's Avatar
    Jul 2008
    Connecticut
    I got the not ready message when I went almost two years ago.. My battery had died over the winter.. I drove it around for a week, a couple times on 10-15 mile easy highway speeds and passed easily the next time. They give us one free re- test here too.
    Oh, and we are plug in test only as well, but lots of places do visual checks for cats.
    richierevs's Avatar
    richierevs is offline I Need DRs Really Bad....
    Mar 2008
    Stamford, CT
    Chris, check the knowledgebase. There's a thread out there regarding the rear O2 sensors, Kook's headers and passing emissions.
    Here's the link:
    Emissions, Kooks LTs, Anti-Foulers, & O2 Sensors Revisited
    1FST4DR's Avatar
    1FST4DR is online now I just dont get it...
    Ft Laud.....
    Register the car in florida...
    GlobeWarmer's Avatar
    GlobeWarmer is offline Got Gas Money?
    Sep 2011
    Phoenix
    I've known a few guys here in Arizona (OBD-II plug-in only) that have passed with headers on stock blocks, stock blocks with blowers, and strokers (with and without cats) by using the aint-fouler & steel wool (grade 3) method. It's a lot of trial and error though with getting the right amount of wool in there. If he resets the CEL, a quick drive cycle can put them back in the ready - LINK. Turning the key to the on position for 10 seconds will tell if the vehicle is ready for emissions or not. After the 10 seconds, the CEL will flash and ding if it's not ready. We worked off of richierev's thread that he mentioned above: Emissions, Kooks LTs, Anti-Foulers, & O2 Sensors Revisited
    - Taylor
    2006 Jeep Grand Cherokee SRT8
    Inertia 426 - Ported & Polished Heads - 230/234 Cam - Stainless Works Headers - FTI 3800
    Paramount Performance NAG1 - Custom 3" Exhaust w/ Cutouts - BWoody CAI
    Composed by Johan
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    I just got off the phone with Chris. Prior to the 440 the engine was SC'd with the Kook's headers and anti-foulers were in play. The car passed emissions last year. CT has changed the software for emissions which is more stringent. The test now looks for pending or stored codes that do not throw a CEL. One thing to try, is to change out the steel wool with fresh/clean material. Due to exhaust heat the steel wool in the anti-foulers will breakdown over time.
    Side Note: the Mopar 6.1 TCM creates an OEM pending code which may cause a failure at emissions in CT.
    Sep 2011
    Phoenix
    Sweet Jebus, CT is rough.
    Carfinish's Avatar
    Carfinish is online now Capeeesh!?
    Nov 2005
    New York
    Quote Originally Posted by GlobeWarmer View Post
    and on top of that they have monitoring cameras that will not allow the emmissions machine to run the test.. unless it is logged into their server and feeding video real time. Place near my job got such equipment this past October.
    RIP
    12.869 @ 102.02 Stock 5.7 w/ C&L, Predator, JBA Cats, Volant catback, 3.06 Getrag, DRs & skinnies
