Modern Mopar Performance Group
    David Weber's Avatar
    David Weber is offline Modern Muscle Performance Group
    Apr 2010
    VA
    6.1 plenum gasket - Help that catch can reduce oiling
    Anyone that has had a plenum cover off the bottom of a 6.1 intake knows that the sealing capability of the stock gasket and sealing area is suspect. We are offering a .060 rubberized coated gasket to eliminate any oil that maybe leaking over from the PCV section of the plenum.
    This is also something to consider for the high boost guys who could be pushing psi the other way and increasing crank case pressure plus bleeding boost. Either way it is a inexpensive upgrade to do.
    Gaskets will be $34.95+SH (price can come down for QTY purchase)
    Give us a call. Won't find on website just yet.
    Thanks Dave 276-666-1934
    HEMI~C~'s Avatar
    HEMI~C~ is offline Ahhh..blown, stroked and injected!
    Oct 2004
    Raunds, Northamptonshire UK
    I haven't noticed any real evidence of this during my dis assemblies but I have always considered it suspect myself for the boosted apps and certainly would feel much more comfortable with something other than a steel shim gasket in there.
    Any pics?
    Stupid Nasty.... FBG 2.0 9.59 @ 148
    FBG 3.0 underway.... Arrington Aluminum 440/Vortech XX trim /4.2KB /Turbo/Nitrous testing in progress
    Apr 2010
    VA
    Pics will come
    I agree it is not on all but some. I see more new intakes than I do anyhting else and some of these new intakes have a terrible mating surface. till now we have been coating the plenum gaskets with copper coat to help prevent leakage. It is one of those preventive medicine things. Drink a little OJ before you get the cold.
    The added .045 plenum volume is directionally correct but I am sure not measurable on a dyno. Sort of like the bolts you drill out on the front of the race car. Every little bit helps
    Dave
