We decided to start a new thread since the direction has changed so many times in the last year regarding this car. I will start with the bottom end.
6.1 Block
Manley 4.05" Crank
Manley Pro-Series I-Beam Rods
ARP 2000 Rod Bolts
Manley 8.5:1 CR
Chromoly Wrist Pins
Total Seal Steel Rings
Stock Caps and main bolts
Clevite main/rod bearings
A1 Technologies Head Studs
Manley double roller timing chain with torrington bearing
Cometic Phuzion Head Gaskets
PWR Mean Street Heads
Copper Beryllium Seats
Titanium Valves
PAC 1518 Springs
Sheet-Metal intake
Nitrous Pro-Flow kit
DSS 9" IRS
1400hp Axles
3.23 Gears
Hellion TT Kit
Ball-Bearing 61mm Turbos (possibly switching to Precision 6265 turbos later)
4" Intercooler
Eboost2 boost controller
ATI Balancer and Flexplate
SHR Transmission
Weldon Fuel System
Modified Hood
We are not sure what wheels we will be running yet but we will be using M&H Tires. The converter will be a 2400 PI converter unless something changes in the near future. Still dont have a catback, but we are working on it. Mopar police oil cooler as well as an auxilary trans-cooler will be added. Remote 12-15 gallon fuel cell sitting below trunk mat behind rear wheels.
That's going to be one helluva setup!!
"I'm not speeding I'm data logging" rdrd90
That is serious. what kind of manifold is that?
High Comp 392.
Those turbos are alittle small.The intake is pretty
05 Magnum R/T RWD inferno red
Franks racing Sidewinder cam w/SRT springs
Flowmaster super 40s w/custom tails
SRT headers and Cats
PRO-TORQ 2800rpm STALL CONVERTER
for converter call (203)969-2886
those heads are sweeeeeeeeeeeeeeeeeeeeeeettttttttttttttttttt!!!!!! !!!!! check out the seats on those things!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Wow..... Cant wait to see the end result!![]()
WOW!!
2008 300c -KING MOTORSPORTS
NOW--PWR 397 Stroker, PWR 6.1 heads, Modern Muscle
6.1 intake and 90 TB, 3.06 Getrag, BB Dominator, SHR trans, SLP pulley, SRT Headers, Corsa exhaust, LOTS OF BT!!!! (Tuned by Dave Foreignmuscle)
PWR heads and Cam PB; 12.91@108.24mph
NEW PB on street tires and weak launch 12.41 @ 115.77
New PB on the way...
