Well this car just made its first pass at Mopars at the Strip. It was a 60ft only pass as he has 6 license passes to make today. Now that they are running at a public event, I can share all the pics.
I will keep everyone posted on the results as they are available and you can watch the race live here.
http://www.ustream.tv/channel/from-the-tower-at-lvms
This image has been resized. Click this bar to view the full image. The original image is sized %1%2 and weights %3.
From Tim regarding the first pass
"Converter blew..cut a 1.35 60ft"
"Car wouldnt come off the rev limiter and had to shut it down at 330ft mark, coasted to a 6.72@76mph in the 1/8"
I think the car is done, seems he went through the converter on the first pass unfortunately. Definitely sounds like its going to be an easy 5 second 1/8 mile car though and with those 60ft times, should be no problem running 8's.
DAaaaaaaayyyyyuuummmm
PPP stage 2 Heads, Super Spartan Max Cam, Inertia Ported/Coated Intake, Zoomer's, Kooks, no cat's, Jet 180 t-stat, BT catch can.
435rwhp/413rwtq..mustang dyno
More to come
Any video of it on the dyno or at the track, missed the live feed?
Again Holy Bajezzzeus!
2008 300c -KING MOTORSPORTS
NOW--PWR 397 Stroker, PWR 6.1 heads, Modern Muscle
6.1 intake and 90 TB, 3.06 Getrag, BB Dominator, SHR trans, SLP pulley, SRT Headers, Corsa exhaust, LOTS OF BT!!!! (Tuned by Dave Foreignmuscle)
PWR heads and Cam PB; 12.91@108.24mph
NEW PB on street tires and weak launch 12.41 @ 115.77
New PB on the way...
What type of monster is that!!!!!!!!!!!!!!!
All performance work done by mdmperformance.com
Come to Dinwiddie on APRIL 22nd and see this Beast in Person.
what trans?
I'd imagine whatever you moved to would have something to handle the power... a NAG1 seems like you would be shifting *way* too many times for a turbo car...
2012 Ram 1500 Express - 4x4 - HEMI - Black
th400 trans. non lock up converter on trans brake
3 Gears for the Turbo 400. But would it be with a Reverse Shift Pattern?
