I dont want to name any names, but we had a 5.7 customer swap to our heads and cam along with an eagle intake and below are the before/after results.
This image has been resized. Click this bar to view the full image.
Ok.
Numbers seemed real low before. Look good at 380. Were they swapped for eagle heads too?
High Comp 392.
Okay... There's a bump in HP and TQ, but pretty meaningless without details.
12.645@108.18
^^^^x2
the customer had a competitors heads and cam along with an eagle intake manifold.
Now he has PWR 5.7 ported heads, PWR cam, and the same eagle intake manifold.
It was the same tuner for both builds.
Was your cam and head specks comparable to the competitors you took out?
2007 SubLime || #1035 || Mods: Arrington 440 ci stroker, 90mm TB, roller rockers and custom 5 pt rollbar, American Racing headers and catless mids, Paramount 8.8 differential, 5K Dominator Converter, drive shaft, DSS 1400hp axles, Transmission built by Enhanced Transmissions, SRT Corsa Catback, LMI prototype headlight CAI, Lots of BT goodies, "Show and Go" install package by BFNY Performance, Tuning by JerseyBoy
1/4 Best - 4/26/13: 10.58 @ 128.47 2011 Atco Vid, Thanks RobAGD: Wheels Up!
'06 Charger, Magnesium Pearl RT - My awesome DD
RIP nhDave - Never forgotten
Bummer. Would have been pretty interesting if you would have keep the intake consistent.
The intake manifold is the same in both builds.
The only difference is the heads and cam.
The competitors heads are listed as their ported heads and the cam had zero specs written on it.
I heard what kinda cam is in there. Should post the info up and let people make their own asumptions.
Sooo are they the same lift cam, same stage heads? This isn't much of a comparison other than they were both 5.7's
Just lurking. Hemi Registry #1050
You don't really compare cams to each other at the same specs. Obviously, the same specs make the same power. There's a lot more to a cam than it's peak lift and duration numbers. What you'd want to compare is cams that are designed for the same thing. Both cams are marketed as mild cams. Neither shakes the car, both cruise like a camry, neither kills gas mileage. They both were designed for the same purpose. The first setup didn't do what was expected. The PWR setup did what it was supposed to and then a little more. More power with zero loss in street manners = superior cam.
www.EFISpecialties.com
EFI Tuning Specialist
Tuning the fastest, most powerful Hemis around
"In theory, there's no difference between practice and theory. In practice, there is."
So you put a stage 1 entry cam to a stage 3 in the same league?
What does something like this cost I am interested in getting some more power, also what type of tuning do I need too do. New too these cars
