Results 1 to 13 of 13
    PWR_Brad's Avatar
    PWR_Brad is offline Supporting Vendor
    May 2010
    Richmond, Va
    New Engine: Max Wedge 413Ci
    We have a new motor that we are working on that is based off of the 5.7 block. The motor is bored and stroked to 413ci for the maximum in hp/tq for your 5.7. The motor is being designed for NA applications and maintains a cylinder wall thickness identical to our 6.1 stroker combinations.
    NA Compression Ratios
    10:1 using 03-08 heads (Ideal truck motor)
    10.5:1-11:1 using 6.1 heads (Ideal 93 octane NA motor)
    11.3:1-12.3:1 using eagle heads (Ideal for 93 octane NA motor)
    Boosted Compression Ratios
    8.8:1 using 03-08 heads (12-15psi capable)
    9.75:1 using 6.1 heads (10-12psi capable)
    10.3:1 using eagle heads (up to 10psi capable)
    For different compression ratios, we can order a custom piston to suit your needs. This motor is really at home as an NA engine.
    413ci Longblock: $7000 (No Core Charge) Only 1 at this price
    Comes standard with Manley crank, rods, and pistons. Iron rings, clevite bearings, camshaft, timing chain, lifters, forged pushrods, eagle mean street heads, cometic head gaskets, and factory main/head bolts.
    In an 09-10 5.7 vehicle, power output is estimated to be 450rwhp/475rwtq due to camshaft and rpm limitations.
    In any non-VVT platform, we are shooting for 500rwhp/500rwtq.
    These estimates are based on a ported 6.1 intake, 90mm tb, longtube headers, free-flowing exhaust, and a custom tune.
    Available options include the following.
    Tool Steel wrist pins: Boosted/N2O
    ARP Main/Head Studs: Boosted/N2O
    Pro-Series I-Beam Rods: Boosted/N2O
    Coated Pistons: Boosted/N2O
    Steel Rings: Boosted/N2O
    Gapless Rings: Boosted and NA applications
    Ported 6.1 Intake
    Longtube Headers
    90mm or 100mm Throttle Body
    Adanac Charger's Avatar
    Adanac Charger is online now It's a family sedan... Hang on kids!
    Brooklin, Ontario, Canada
    Very Cool!!
    The original 413 Max Wedge in '62...
    from maxwedge.com...
    Displacement.................413
    Bore.............................4.19
    Stroke..........................3.75
    Compression ratio..........13.5 to 1 !!
    Horsepower...................420
    Torque.........................470
    2006 Charger R/T with Road & Track .-- .Bright Silver
    PWR 426 / Apache Heads / Fr-240 Cam
    Awesome install by HalfFast Performance !! . . Awesome tune by JerseyBoy !!
    MOL SRT-8's Avatar
    MOL SRT-8 is online now SHOW & PERFORMANCE
    Dec 2006
    SAN DIEGO, CA
    Quote Originally Posted by Adanac Charger View Post
    Very Cool!!
    The original 413 Max Wedge in '62... from maxwedge.com...
    yep, that's the numbers that they gave NHRA.
    bmeyer40's Avatar
    bmeyer40 is offline 224/230 cammed 5.7
    Dec 2009
    Park Hills, MO
    What's the bore and stroke?
    Posted from the Captivate!
    2005 Silver Magnum R/T
    5.7 Stock Bottom
    12.115@111mph 1.69 60'
    bmeyer40's Avatar
    Dec 2009
    Park Hills, MO
    Bump
    My guess is that they'd use a 4.08 stroke... that would calculate to about a 4.015 bore. ?? Just a guess on the stroke.
    Fargo59's Avatar
    Fargo59 is online now building for the better!
    Welland ON
    so if it's 5.7 based, it's not really a wedge is it?
    Do you mean because it's a stroker and not 'oversquare'?
    Well... I have it from a good source that I'm wrong on the 4.08 guess.
    Hemi31's Avatar
    Plattsburgh,NY/Lorain Oh
    No because it's a Hemi and not a wedge motor(IE:383/413/426/440) from the 60's and 70's.
    RIP NHDave
    1FST4DR's Avatar
    1FST4DR is online now I just dont get it...
    Ft Laud.....
    Quote Originally Posted by fargo59 View Post
    Thats ok ,These really aren't Hemi's either
    tony292 is offline LX Padiwan
    Dec 2010
    4.25 crank?
    bmeyer40's Avatar
    Dec 2009
    Park Hills, MO
    My guess is a 4.08 crank that has been reground if that is even possible. Rod journal size is probably sub 2.0. And word from Pwr?
