    BMWDON's Avatar
    BMWDON is offline I-495 Hater
    Dec 2004
    Southern MD
    max rpm on mean street heads?
    I don't know if it's a perception or tuning, but it seems like folks running a s/c (procharger or vortech) aren't showing dyno's that run up to 6700ish rpm, seems like 6400rpm is the peak. Is this a head/valve spring/valve train restriction? rpms of the s/c maxed at at 62-6400 engine rpm? My current redline is 6700 if not more, maybe 6750.
    Is it just ideal to max out a s/c engine to a lower rpm redline than a na motor?
    -Bill
    Challenger Mods: PWR 393, Mean Street heads, Procharger D1 pushing 11+psi, SHR Nag1, DSS 1400 axles and drive shaft, SHR trans but with Paramount Dominator and stage2 valve body to finally be error code/limp mode free. BBS CH-R's and custom splitter with 2011 front spoiler. AAC SMD halos, 3K fog lights, white stripes, cervini wing, hotchkis springs, custom 10" sub w/ kicker amp, sequential tail lights.
    2009 Dodge Challenger SRT8 Procharger D1 Supercharger: 10.895 @ 126.720 MPH
    roswald0511's Avatar
    roswald0511 is offline RIP Clifford
    Where the Wire was filmed
    The TCM was the problem. Now that the Tranzformer is in beta testing we might be seeing 7000rpm shifts soon.
    BMWDON's Avatar
    Dec 2004
    Southern MD
    interesting....figured if I could redline at 6700 now, I should be able to shift there after a s/c install, maybe not hold it, but make the attempt before the tc slipped.
