Vortech Satin Aftercooled Supercharger system for the 06-10 SRT8 Jeep
Group buy of 3 or more for $6345.88 installed. Contact us for non-installed pricing.
- <LI itxtvisited="1">V-3 (self contained lubrication - no oil lines necessary) Si-Trim CCW rotation supercharger with an extended 6-rib belt and secondary cog drive. <LI itxtvisited="1">Air/water charge air cooler (closed loop) increases performance and reliability of supercharger system and includes:
<LI itxtvisited="1">Supercharger drive system includes all necessary belts and pulleys. <LI itxtvisited="1">Billet aluminum mounting plate assembly mounts the supercharger and power steering pump. <LI itxtvisited="1">High flow inlet duct with re-useable high flow air cleaner. <LI itxtvisited="1">Hand-held programmer controls ignition timing and fuel enrichment. <LI itxtvisited="1">Fuel system upgrade includes larger fuel injectors and a 2 bar MAP sensor.
- <LI itxtvisited="1">Welded charge air cooler core assembly with aluminum discharge tube, Bosch compressor bypass valve, silicone sleeves and stainless steel clamps. <LI itxtvisited="1">Charge air cooler water storage tank with hoses, clamps and plumbing <LI itxtvisited="1">Compact water circulation pump for closed loop cooling.
- Large capacity, dual pass water cooler.
- (6.1L system also includes a fuel pump voltage booster assembly)
CMR tune for $200
and Dyno Tuned for $400
This is the same kit as:
This image has been resized. Click this bar to view the full image. The original image is sized %1%2 and weights %3.
This jeep had long tubes as well.
PM me for more details.
Bump!!!!!!!!
I'm so tempted. Can you do 0 down, 0 percent @ $10 per month for a 634 1/2 months? Seriously, that is a solid price.
DAVE -- 2007 Grand Cherokee SRT8: Mopar exhaust, Volant CAI, DCX Depot CMR tune, BT catch can, BWoody springs and end links, Jeepin by AL upper control arms
Can you hyperground the leads to the mason jar and get even more torque and hp?
Can you pm me or text me the price with out install or a tuner
PWR 393, Twin 6262mm Turbos, SHR trans, Fore Fuel system, Wilson Hemi Sheet Metal Manifold
880 RWHP 775 RWT at 16 psi and 17* of timing
Tuned by Robert@ Ditos motors
Walk Softly And Carry Two Big A$$ Turbos!!!
You have a pm sir
I'm also interested in a non installed price please
2013 Ram 1500 Sport- 4" BDS Lift, Fuel Krank Wheels with 35" Tires :-) and a bunch of other crap lol
2011 Ram 1500 Sport (Traded in)
2010 GCSRT8, 20" (Traded In)
2008 Superbee #558/1000, Traded in and missed
2005 Crossfire, Traded in on Bee
YEEEEEEEEEEEEEESSSSSSSSSSS send me a pm! Also please include a price with a t-trim upgrade. Non installed please!!!!!!!
Thank the SRT gods for PWR!
