Results 1 to 15 of 21
    PWR_Brad's Avatar
    PWR_Brad is offline Supporting Vendor
    May 2010
    Richmond, Va
    Aluminum 5.0L Hemi $6000
    Here is your chance to own a very rare 5.0L Gen III Aluminum Hemi Shortblock. These blocks were manufactured to be built by Mclaren Engines and used to race in the Grand-Am circuit which is limited to 5.0L engines. This engine utilizes the following components.
    Bryant Billet Crankshaft: 2.953" (This is a $4000 crankshaft according to the guys at Bryant)
    Carrillo 6.500" Connecting Rods ($2600 a set according to Carrillo)
    JE 4.080" Pistons/Rings/Wrist Pins
    ATI Balancer (Built specifically for use with the Bryant crankshaft)
    P5153896AA is the block part number. It was never available for purchase and from what I understand, only 5 were produced, but this could be incorrect. Up for sale are numbers 003, 004, and 005. They are sold "as is" and I have no idea what it would take to work in our cars. It is setup to be a dry-sump motor and Daily engineering did the dry-sump kit for it. The cylinder walls are already plateau honed to near 4.08". The block is considerably lighter than the iron block and even lighter than the production aluminum blocks. All components are in-house and can ship the following business day.
    We will be keeping 1 & 2 and will be installing one of them into an older road runner.
    This image has been resized. Click this bar to view the full image. The original image is sized %1%2 and weights %3.
    MuscleMan305's Avatar
    MuscleMan305 is offline Hopped up on Super Supreme
    South Florida
    Whats the catch?
    RobAGD's Avatar
    Reston, Va
    These were never run ?
    MM305 - You are going to have to put some coin into these, but they should be real fun in a light car without the factory electronics. You would want to spin this motor, huge bore short stroke this thing should scream with the air our heads move.
    I would love to see what they did to the cylinder heads for these motors.
    -Robert
    1FST4DR's Avatar
    1FST4DR is offline I just dont get it...
    Ft Laud.....
    Quote Originally Posted by MuscleMan305 View Post
    Whats the catch?
    Why you ready to quit bench racing??? Buy that thing Ill cut you a killer deal installing it..
    ujokin2's Avatar
    ujokin2 is offline LX Guru
    May 2006
    Suffolk, Virginia
    it sure looks pretty !
    N/A ET
    10.44@128 < Once upon a Time
    Joy ride TT Challenger 9.71@143
    Slow Poking along in Stock to a T 6.1
    PWR_Brad's Avatar
    May 2010
    Richmond, Va
    These motor wer made to run in the high RPM
    junior666@TTCreations's Avatar
    junior666@TTCreations is offline Home of the 1191hp Jeep!!
    Dec 2008
    li ny
    Is the block the same size as the Gen III cast block with just less displacement?
    Chris Hull
    (516) 532-6662
    All LX/LC SRT and RT welcome
    ujokin2's Avatar
    May 2006
    Suffolk, Virginia
    Quote Originally Posted by PWR_Brad View Post
    Thats were its going to catch ALOT of folks.... Our TCM programing has not quite caught up yet to the point we can rev these babies high enough to take avantage of the potential. You have to change the electronics and go for the FAST system
    1FST4DR's Avatar
    Ft Laud.....
    -Robert
    Agreed Rob, The Manifold Wilson made for this combo is around here somewhere. Rtr0id has one right now he's playin with.
    RobAGD's Avatar
    Reston, Va
    Well also youhave to worry a bit about the factory valve bits.
    As of now the ONLY after market rocker system out is the Jessel and you are looking at $4k plus the head machining to make it work.
    I would think the dry sump set up would be 7-10k as well.
    If I could I would build a motor like this for a stripped out Chally race car... zoooooom
    -R
    PWR_Brad's Avatar
    May 2010
    Richmond, Va
    4k for dry sump oiling from daily engineering. The stage 4 heads will handle 8500rpm with the factory rockers. rollers not needed. The corvette C5r uses the same swipe style rocker.
    challengers already competed in that race using factory rockers.
    Cam's Avatar
    Cam
    Cam is offline effectiveness is not always pretty
    Oct 2005
    Riverside, Ca
    4k for dry sump oiling from daily engineering. The stage 4 heads will handle 8500rpm with the factory rockers. rollers not needed. The corvette C5 uses the same swipe style rocker.
    The rockers aren't the major issue. It's the amount of spring pressure you can safely get away with to run that RPM. And with the dry sump, you've solved the other issue at that rpm.
    But man would I love to have one of those to play with. Wanna cut a deal, I got a couple of spare kids here you can have. I swear they're almost house broken.
    RobAGD's Avatar
    Reston, Va
    Ill be honest if I was racing it I would not have warm fuzzies running the factory rockers.
    4k for the complete Dry System ? (Pan, pumps, filters, hoses & fittings ?) because thats not bad at all.
    Still some sexy stuff there.
    -R
    CVP33's Avatar
    CVP33 is offline America...fvck yeah!
    Feb 2006
    Oak Ridge, NC
    I've done some research on these motors and found that they give me a woody. You are welcome again for my expert opinion.
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    They belong in a 67-69 A body
