Wow, to cut them I took a 2 5/16 hole saw and made a hole, not rocket science.
Where I paced the gauge and where you want your gauge could be different, therefor I stopped cutting the holes Pre done. BTW the glpanel part isn't the "trick" to this idea "I"came up with in 2007, it's the mounting it
I fabricated this mount for my boost gauge when I had my Magnum S/C'd.........
I made it so the gauge was angled towards the driver...........it has a lip on both sides that I used to epoxy it to the rear of the vent trim.............Not sure if I still have the template I made to cut it out......
HEMI Registry #1575.......PB - 13.390 @ 106.67 Mph.
Proud Member of The WTFDTSG Club.........
Looks awesome!!!
1(855) 3GC-Parts-------------------------------------------Gussets, Trophies, WineRacks and Metal ArtworkYou Dream It, We Can Build It-------------------------------------------
Sure does. I think redfox is sending me the panel anytime soon... I'll post pictures when it's hydrodipped and mounted.
Skullboy - did you just epoxy it on there?
Thor From Sweden - MSRT '06Procharger P1SC-1 // Ford 80lbLegmakers // AAC // Billet Tech // 3G CustomZ // Diablo
Innovate LC1 // Nitrous Outlet Addict
how does this affect lets say the dual zone climate control? is there much difference in the heating/cooling of the car? also do you guys block the vent off on the inside? or does hot/cold air just blow on the gauge?
Im planning on not doing anything with the vent behind the panel - I'm going to let it be as it is and see what happens.
