Originally Posted by
spraying mantis
The hood seems legit. All the installed pics they had did'nt show any goofy gaps at the fenders or the hood stickin' up higher than the fenders (most common to after-market panels). But with all fiberglass it's hit or miss sometimes 'cause they're almost never the same twice. I'd say go for it if you want it. With the intake, it's just a box to channel the air taken in trough the scoop directly into the cone. I'd say the advantage of it is to force more air and cooler air at that because it doesnt suck some of the hotter air from the motor. No need for pins, I've installed a hundred f'glass hoods, as long as the metal striker is on it and reinforced (which it is) you should'nt have a prob. Hope this helps.
