Results 1 to 9 of 9
    DanSS24's Avatar
    DanSS24 is offline Race Safe
    Jul 2008
    Aiea, Hawaii
    Which Coilover is best for all around performce...
    I basically use my charger for patrol duties and drive my car hard so I want a coilover kit that will be able to handle the abuse. Or...should I just go with springs and heavy duty shocks? Right now, I have hotchkis springs and koni str.t shocks with stack performance sways and bwoody endlinks, but right now I bottom out when going over bumps and some driveways.
    2008 Charger R/T
    True CAI (fender mounted filter), Flowmaster 40's mufflers with 5" Stainless Steel tips, Hotchkis Springs, Koni Str.t dampers, Stack Performance "Chubby Pro" Sway Bars w/BWoody end links, Gloss black Factory Reproduction 20" SRT 20x9 wheels with 275/40's on all 4's, R1 Slotted/Cross drilled rotors & Hawk pads w/Stop Tech SS brake lines
    Soon to Change: Mopar Stage 1's in place of Hotchkis, Bilsteins in place of Koni's
    triste214's Avatar
    triste214 is offline LX Newbie
    Aug 2008
    long island
    bump for you
    typicalmarine's Avatar
    Jun 2007
    Maryland
    Don't know what the "best" is but im running the BC kit from circuit motorsports and really like them.
    CircuitMotorsports is offline Supporting Vendor
    Apr 2009
    Are you bottoming out becuase you're too low or because the shocks are to soft? Is the car physically touching the gorund or are you hitting the bumpstops on the shocks?
    "Keep Attacking..."
    Site - www.circuitmotorsports.net
    Email - sales@circuitmotorsports.net
    Phone - 407-325-2176
    Address - 2931 Forsyth Rd Unit 102, Winter Park, Florida 32792
    DanSS24's Avatar
    Jul 2008
    Aiea, Hawaii
    Quote Originally Posted by CircuitMotorsports View Post
    When the front goes over a bump, it feels like it is hitting metal below my feet and when I finish going the bump with the rear end, it is definitely hitting the bump stop. Prior to my suspension upgrades, I took measurements of the height using the top of the wheel opening for reference. The front wheel well was 30 1/2" and the rear was 31 1/2". Today the measurements are 28 3/8" front and rear. Seems like too much, right? I was thinking of using the Mopar springs but I heard differing opinions of the height not being lowered an inch. I'm thinking that with the coilovers I can actually raise or lower it to what ever I want for my needs.
    Bull's Avatar
    Bull is offline THAT JUST HAPPENED!!!
    Jul 2010
    Medford, Oregon
    I love my BCRacing coilovers!
    Apr 2009
    Hmm, well if you need something stiffer than what you have now, a set of the BC Racing coilovers may do the trick.
    You can control stiffness via damping knobs and you can also set your height where you need it for the roads you're driving on.
    Feel free to shoot me a PM if you want some more info
    DanSS24's Avatar
    Jul 2008
    Aiea, Hawaii
    Thanks for all your help...now I know where to go for my suspension needs. Once I figure out and fix my knocking noise when I turn my steering wheel, I will get me a set of BCs.
    Apr 2009
    No problem
