Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: TC updates?
  1. #16
    tank8289 is offline Supporting Vendor
    Jun 2007
    West Milford, NJ
    I can't see the price getting much cheaper because it require more work to cut more gears, the only thing we would get a better deal on is material, so i can see the price getting much better. I can get a price if you guys get a definite interest, but other than that i'm going to stick to my much cheaper solution until it cannot handle any more power. My hope is that the cryo treated case will handle up to about 8-900 crank hp.
    392 Stroker, Builder Bill TC, Builder Bill tranny, LXAS LVLI Tcase, Novi 1500 10.5psi, 150 shot of nitrous, tuned by Josh @ HHP
  2. #17
    Midnightsun300c's Avatar
    Midnightsun300c is offline Large Carbon Footprint
    Eagle River, Alaska
    Quote Originally Posted by tank8289 View Post
    Well rats! I was assuming/hoping the lions share of the cost would be the setup with the material and cutting cost a distant second. I'll be interested in how your cryo holds up. After talking about cryo in this thread if reminded me of when Meister treated his axles way back when. From what I remember the cryo didn't do much for the axles as he snapped them his first outing. Best of luck to you.
    Honorary First Member – LX AWD – 11 Second Club
  3. #18
    Eagle River, Alaska
    Quote Originally Posted by Midnightsun300c View Post
    Just wanted to follow up on this...Meister was kind enough to reply to my inquiry regarding his experiences with cryo. Although he did snap his treated axles he thought that the axles were much stronger. So maybe cryo is not the end all solution but it may be a big enough step forward to make it worthwhile. In the end though I think 60' times will be the true test so I'll will be interested in your results. Good Luck. I''l be hoping you get 1.5" 60'...Then I'm all in!
  4. #19
    Mag-Yum's Avatar
    Mag-Yum is offline LX Padiwan
    Mar 2009
    Kinnelon, New Jersey
    .... My hope is that the cryo treated case will handle up to about 8-900 crank hp.
    It will for the first 2 hard starts on street radials.....but the 3rd????? Um.....* caugh*.... well.......um......*silence*! LOL The bigger parts held up ok but its the simple things.....those not thought about......"that'll get ya!"
    Any update on this?.....he heSnap Ring "whosie-whatsie" thing ????
  5. #20
    MagnumManAWD's Avatar
    MagnumManAWD is offline LX Oddball
    Jun 2008
    Central FL
    I don't know if I missed this discussion somewhere, but what about the GCSRT8 TC and an adapter plate and the appropriate input and output shafts?
    Magnum Man
  6. #21
    Jun 2007
    West Milford, NJ
    Quote Originally Posted by MagnumManAWD View Post
    front output shaft is on the wrong side of the transfer case.
  7. #22
    Jun 2007
    West Milford, NJ
    Quote Originally Posted by Mag-Yum View Post
    Yea seems as the first small failure to the beefed up case, even though what broke was dodge's original part. Snap ring around the input shaft failed. Strange considering that its not really under load.
  8. #23
    Gabe's Avatar
    Gabe is offline www.custombilletstore.com
    Stoneham, MA
    Bump, any updates ?
    Billet Tech custom billet products Online Store
    Many pictures of our products can be viewed here
  9. #24
    Jun 2007
    West Milford, NJ
    Snap ring was replaced with a stronger one, hopefuly mag-yum will have some updates soon!
  10. #25
    srt007 is offline LX Guru
    Oct 2008
    miami,fl
    any news on it holding up?
    2006 charger srt8*** low comp 426,billet main caps,arp hardware, ported heads,custom cam,xv manifold, air/air front mount intercooler,twin precision billet p6262 ball bearing turbos, ati balancer, 150shot zex perimeter plate no2 system, custom dedicated 1 gallon fuel system for no2,90mm throttle body,paramount performance nag1,2800stall converter(currently upgrading to paramounts 4000 stall),dss axles,stock open diff(currently upgrading to quaife and 3.55 gears),
    900whp+ at 13psi(boost only) on 93oct, well above that when i spray!!!!!
    Diablotoona tuned/tamed the BEASTTTT!!!
  11. #26
    Jun 2008
    Central FL
    What about the Ram Truck trasfer cases?
  12. #27
    ThaCuda is offline Destroyer of Bacon & Wings
    Apr 2011
    NC
    gotta see this come back to life.. Any updates here? I've got plans for my awd, and I'm already concerned about the converter and shot breaking my tcase.
    2005 Magnum RT AWD. Needs mo' powa!
    1966 Barracuda.. Plenty of Powa'
    2005 Dodge 2500 Cummins. Plenty of Powa'-Sold
    http://www.youtube.com/watch?v=4wdwXe1zAF8
    and work:
    www.guaranteesmatter.com
    http://www.lxforums.com/board/signaturepics/sigpic43550_1.gif
  13. #28
    Jun 2007
    West Milford, NJ
    Magyum will have to post up his results but after the snap ring replacement transfer case is holding up beautifully after a few hard starts. My car was just street tuned by rdp on pump gas making 9psi. I'm still running the stock transfer case to test how far it can go. My beefed up case is a backup. Once I'm back from vacation in two weeks we will be tuning for 100 octane and 150 shot of nitrous hopefully, and also some dyno runs. Then the track if all goes well.
