Results 1 to 2 of 2
    USCG Charger's Avatar
    USCG Charger is offline LX Guru
    Jan 2007
    How to buy pulley from KB?
    Hopefully this gets through to you guys. I have called over 100 times starting at 0800 the min your doors are suppost to open, but the line is 100% busy all day long. I have also emailed and have not got a response. So this is my last ditch effort. I'm running a Mr. Norms 8 rib kit that has a 8" lower pulley. This lower pulley with a 3.25" upper will net me too much boost (24 lbs). I want to be in the 12-16 range at most. How can I get there with changing the upper pulley and where can I but it?
    Mike@KenneBell's Avatar
    Mike@KenneBell is offline Kenne Bell Tech
    May 2009
    Rancho Cucamonga
    Customer has been taken care of
    Mike@KB
