Option 1. Provide a plug and you deal with the rails and injectors
Make it automatic and drain your bank account even more.
06 Charger SRT-8 Brilliant Black Pearl Options I,II,III & Sunroof
Mods: Arrington 8:8 compression 426/Kenne Bell 3.6LC/Kenne Bell 150m Throttle Body/3 Pump Fore Fuel Hat/KOOKS Long Tubes w/High Flow Cats/Labonte Water Meth Kit/Builder Bill Trans, flex plate & Dominator TC/Builder Bill 8.8 w/3.08 gears
843rwhp/766tq -16lbs
K, here we go. This configuration with the 2.8 blower housing. The fitting is 3/4" away from hitting it. The blower housing housing is 8" wide. From the outside of the baseplate to the center of my unit is exactly 2.5". So worst case, intall the 90 degree adapter facing backwards and then a tight sweep 180 AN fitting coming back fowards. that should clear anything you got going on.
Or you could face it towards the front coming over the top of the filler side.
why dont you just use an npt fitting like on fuel hats? the angle wont take up as much space.
i still owe you a phone call...
Follow my build and racing! www.facebook.com/bboypersiart 9.65 @ 139 - 1.380 60'
Sponsored By: Drag-On Tuning, HHP Racing
Make one for me and dont forget i want a fancy cooler too![]()
426 Arrington,,Tranny ,diff, half shaft Paramount
Kenne Bell tune By Lafrad
Performance and build by BFNY
Any update on this Cam?
Nothing production wise, the other stuff has eaten me alive. But as soon as I repair my mill, I'm making two of them, you want one Mario??.
Even though they won't be super duper fancy like what you'd normally see on a CNC machine, it will be adjusted so there are no exposed bolts. BTW, the test unit works like a rock start, absolutely perfect from what Randy tells me. So I'm pretty stoked.
where do i apply for beta testing?![]()
For sure Cam
I m tired to see full of oil in my garage !!!!
Don't forget mine Cam, LOL oh and my other toy.
2006 Black R/T- Inertia 5.7 Based 370 with Eagle Big Valve Heads & Custom Blower Cam, Kenne Bell 2.8LC Supercharger with 148mm T/B & CTP'S KB Stand Alone Drive, Heat Exchanger & Oil Fill/Seperator, Dynatech Long Tubes & Catless Mids, Dynomax 3" Catback, Paramount Transmission, Dominator T/C, 3.06 Getrag with DSS 1400HP axels & Drive shaft, Willwood Brake Upgrade Kit and AFCO Coilovers. Best ET 10.49 @ 129.72
2012 Black RAM 1500 Sport 4 X 4 DS InTune, BT Catch Can
Where do I sign up?
So what if I drive a stationwagon, my other car's a rwd 540hp, Supercharged Hemi that will blow your doors off, oh wait thats this car.
'07 Magnum SRT-8: Diablo Predator, QTP Cutouts, 180* Jet Tstat, BT catch can, and underhood dress up kit, Hurst Shifter, custom switch plate in center console and ashtray,Silverbox, Killerglass, custom radiator from Joelvan. S4 Labonte Water Meth Kit, Kenne Bell 3.6LC,SHR Viking, in the works DSS 1400hp shafts on a wavetrac diff
First you need to stop calling me and telling me what I'm doing wrong, that would go a long ways ya nit wit.![]()
Done Mario.
Yours in one of them T and got the parts yesterday, will finish fixing the mill tomorrow and get rocking bud.
Wellllllllll, I guess ya just did.![]()
