Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 55
  1. #16
    Cam's Avatar
    Cam
    Cam is offline effectiveness is not always pretty
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by typicalmarine View Post
    I'm not sure what size would be best. I'll have to measure the phenolic spacers - but a tad thicker than the two put together.
    Whose spacers do you have?.
  2. #17
    typicalmarine's Avatar
    Jun 2007
    Maryland
    Block shaved:
    Intake fins clipped and shaved:
    Both heads are 5.7 heads (bottom are my PPP heads with intake port matched to 6.1 - top are Franks SS heads)
    Two sets of phenolic spacers needed right now for clearance:
  3. #18
    Jul 2008
    Hughesville, MD
    The 6.1 what? I'm running two 6.1 port shaped phenolic spacers now.
    Intake manifold can find then cheap now
    CAM ONLY RECORD HOLDER 12.34 @108.89 & 1.66 60'
    Email mailed tuned by Brent@dtpracing.comComp268cam,
  4. #19
    Jun 2007
    Maryland
    It's too late for me to go 6.1. I already have Skippy T. whipping up some of his airbrush magic on a eagle intake for me.
  5. #20
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Ok Val, those spacers are .100 thick. So no problem bud. Also those spacers don't seal very well by themselves. If the thickness is enough and you don't want to spend any additional money. Coat them with copper head gasket spray. That'll seal them up nicely.
    Also if you want, I have a set of GSM phenolic spacers that I'll make you a trade plus some cash for those. The GSM units are still in good shape. And I like having the Bwoody spacers around for the occassional blower build ported head problems that come up.
  6. #21
    MagnumRT05's Avatar
    MagnumRT05 is offline ***Drop Beats, Not Bombs***
    Jan 2007
    Westlake, Ohio
    Quote Originally Posted by Cam View Post
    No, they aren't thick enough for that. But I have an idea that just may work for you Richie if I do something for TM. Let me see what can be worked out. But you'll need to see how much hood or strut bar clearance you have with the original spacers. Then figure on another 3/8" to 1/2" of additional height.
    The Bwoody direct port plates are very close in size to the original spacers, but I cant seem to find them anywhere anymore. Plus I like the quality of the Billet Tech stuff. Hood clearance isnt an issue as I have a shaker hood hole in my hood. I cant/dont want to mess around with my CDC shaker anymore so I have some ideas to cover the hole. Interested in hearing ideas or if a drilled out plate/spacer could be made.
    '05 Magnum RT: 392 Twin TC70 Turbo Build
  7. #22
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by MagnumRT05 View Post
    Well I should start off by telling you these new units are not made by BT. BT makes killer products and I'll miss working with them. But being on the other side of the country can be problematic at times for both parties. So I have a new manufacture local to me that will be making several new products.
    I'll be honest. I have no intention of using a one piece plate. IF I do this, it'll be a waffer design.
  8. #23
    MagnumRT05's Avatar
    Jan 2007
    Westlake, Ohio
    Well, in order to keep this thread on topic, just send me a PM if you think up something. At this point, ill take a direct port plate, a faux 2nd fuel rail system that disperses nitrous, etc
  9. #24
    Sublime130's Avatar
    Sublime130 is offline Not racing anymore!! My Sublime is slow.
    Jun 2008
    Lorain
    I guess I need these. I just made a deal for an Eagle 5.7.
    I PM'd you with several questions. Thanks.
    392 based 6.1 PWR heads. 3.06 Getrag, DSS 1400 HP axles
    Danko Shaker Stock 6.1 intake BBK 90mm throttle body, SRT manifolds
    Paramount DOMINATOR converter 4400
    Supported/Re-Assembled by BFNY. Best ET 11.56 w/ 1.60 60'
  10. #25
    monty1269's Avatar
    monty1269 is offline vajazzle it!....;)
    Aug 2005
    Pompano Beach, Florida
    Hey Cam...
    With an Eagle intake and Eagle heads going onto my '05 5.7... Is there some shaving that is going to be required?? Either on the Eagle intake manifold or the actual motor?????? (looking at pics above)
    Hemi Registry 0436 6.1 block - CTP Dual intake - Modern Muscle ported intake manifold - Indy Heads - PWR cam - FTI converter - TTI Longtube(catless) - 3.06 gears - 17 X 8.5 Borbet TS w/ 275/40 Hoosiers - Diablo tuned!! Billet Tech Goodies EVERYWHERE. ALL Parts supplied by LXF vendors: Afterhours Mopar Performance, SpeedRated, PWR, Modern Muscle, Picklefork...and LXForum members. Installed by: Afterhours Mopar Performance
  11. #26
    Centurion's Avatar
    Centurion is offline Lima X-ray Three Zero Zero Charlie
    Mar 2008
    Grand Forks, ND
    Email sent!
    CenCalLX FTW. FRIed 5.7L w/ custom cam & S/S heads milled, MDS enabled, tuned by Bob @ SVS
  12. #27
    Big Daddy J 300's Avatar
    Big Daddy J 300 is offline Nokturnal Car Club-Orange County Chapter
    Anaheim
    Ill be picking mine up tomorrow =)
    Nok 300C
    Current Sponsors and Supporters: 2Crave Wheels, Nexen Tires, Airaid, Modified Metal Shifters, AVS, Accuair Suspension, Amsoil, Magnaflow, R1 Concepts, Odyssey Batteries, Viair Corporation, Quiet Ride Solutions, American Car Craft, AVS, Sanctiond, Spyder Auto, California Upholstery, Show & Performance, KP Concepts, Blessed Motorsports, GO EZ.
  13. #28
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by Sublime130 View Post
    Gezz, I hope I answered you
    Sorry guys, the PM's are overwhelming at times
    Quote Originally Posted by monty1269 View Post
    Hey Cam...
    I've only cleaned up the ribs on the manifold. But other guys have had to hit the block. I think it all depends on how "off core" (thick) the casting is. But neither one is a big deal. When you lay the manifold on the heads you can see if you need to do some more clearancing.
    Quote Originally Posted by Big Daddy J 300 View Post
    Ya you will .
    I'm here so come on out.
  14. #29
    klids80 is offline LX Newbie
    Jul 2008
    PM sent
    08 black dodge charger R/T R&T
  15. #30
    m37ral's Avatar
    m37ral is offline Armed R/T
    Aug 2009
    Quinlan, Texas
    Cam, I need a set of spacers! I have pm'ed you and emailed you too. Let me know if you still have them.
    Thanks,
    Bob
