Results 1 to 15 of 30
    SKULLBOY's Avatar
    SKULLBOY is offline Veritas Aequitas
    In A Bunker......
    Cool Modern Muscle 3.5L Super Charger Install......
    I was privileged to be the First up here in Canada to own the new Modern Muscle 3.5L supercharger kit.
    I did the install myself over the course of a weekend (I think I am also the first to tackle the install by ones self)...........
    The Kit is well thought out, and contains everything you need.The S/C itself was pretty straight forward to install, but the optional water/meth injection system was a little more complicated.
    The biggest pain in the butt is having to remove the upper intake manifold in order to change injectors, and access the spark plugs.........
    The strut brace needs to be removed in order to get the upper intake off and out. Word of advice, have a new intake and EGR seal/gasket on hand........Don't risk using the old ones......don't want a vacuum leak.......I also changed the spark plugs while I was at it. Since the upper intake is a pain to take off, you might as well change everything, so you don't have to do it over again....
    The Injectors were easy to swap.Just don't lose the little clips that lock them in!!!!!!
    The plugs can be removed only by using a thin wall socket, and extendable magnet as they are way down inside the head.
    IMHO, Kind of a silly design.......requires intake removal to change plugs........
    The Crew At Modern Muscle are always there if you need help, and are quick to get back to you.
    Painted the ProCharger Coolant tank to match my engine cover...
    Factory Injectors.....
    Little bit of a "grit" build up....
    New Injectors installed.....
    S/C Bracketry......
    Ties into the power steering pump mount...
    Additional Idler installed...
    Coolant tank installed.....
    Since this coolant tank doesn't overflow back into itself like the factory tank, the overflow line feeds down into a catch can I installed in front of the front wheel well.......you will need to do this if you race on the track.......
    The SRT/4 MAP Sensor....
    Blow off valve...
    Location of the water/meth injection controller.......I wanted a "stealth like" install.......
    Finished Install.......
    I have set up the Meth Injection to pull from the washer tank, and mounted the pump up in front of the drivers side fender well, on the bumper mount.
    Since I have an older Calibration ID (The oldest one MM has seen so far...), I have some tuning issues with the MM Base S/C tune. Justin & John are working very hard to sort this issue out.Their Customer Service has been outstanding..........
    When properly tuned, and with the Water/Meth injection running, I should be dyno-ing at around 320 to 340 RWHP!!!!!!
    Overall I am Extremely happy with this kit!!!
    If you are mechanically inclined, and have basic tools, you can do this in a weekend.
    Cheers....
    HEMI Registry #1575
    CarDomain Page: http://www.cardomain.com/ride/3926528/2007-dodge-charger-srt8-sedan-4d/page-1
    Rollin on Dueces's Avatar
    Rollin on Dueces is offline Just browsin'
    May 2006
    Benson, NC
    that is awesome!! once you get it tuned put a few videos up for us to see
    2005 Chrysler 300--gone but not forgotten
    J Field's Avatar
    J Field is offline She's Now Bottle Fed!!!
    Sep 2007
    Coquitlam B.C.
    Congrats Ed, Once you get her tuned It will be Quick, after seeing the install last night if and when I pick one up I will have you do the work...LOL!!!
    Personal best 11.82@114mph
    Jet 180 Thermostat, Nitrous Outlet Perimeter Plate, AirRaid CAI W/Scoop, CMR tuned, PT 2800 stall Converter, ZEX Complete Nitrous Kit, Stage 2 268H-13 Comp Cam, Iridium 2 Heat Range Colder Plug, Custom Built Dual Flowmaster Exhaust, Hedman long tube headers & Cat's Deleted, Line lock, AEM Wideband, Autometer Nitrous & Fuel Gauges, Glow Shift Triple Guage Pillar
    Dave's not here's Avatar
    Dave's not here is offline Dave's not here,man.........No, I'm Dave
    Aug 2007
    Cruising the Fraser Valley
    Looked great last night Ed.... can't wait to see you fly down the track.
    2005 Magnum RT: (Cool Vanilla),20" Nitto 420's on Akuza chrome rims, Magnaflow catback, Airraid CAI, silencer removed, Superchips Flashpaq, 180 T-stat, SRT stabilzer bars & springs, de-badged, "Hemi Powered" floor mats, tinted tail lights, custom snakeskin console cover, black Serious Metal catch car, colour matched interior trim, eyelids, RK Viper style hood and a BCLX sticker.
    HEMI airbrushed on the headrests thanks to RJ's Leather Magic.
    Hemi Registry# 970
    loweredtoy's Avatar
    loweredtoy is online now Creator of the Eyebrow!!
    Jul 2008
    Vancouver Island. BC Canada
    looks awesome I can't wait to see what it does on the track
    2007~DODGE~CHARGER
    ~ For ~ A ~ List ~ Of ~ Mods ~ Checkout ~ My ~ Cardomain ~ Site ~
    Thanks Hazman For The Sig Pic
    RTVIC's Avatar
    RTVIC is offline Drive it like you stole it!!
    Oct 2008
    Whalley world Surrey B.C
    THATS FREAKIN INSANE!!!!!!!!!Congrats bro on being the first!!Im jealous..Great install VERY stealth like indeed!!! WOW
    Magnaflow cat back,K&N CAI,Airraid spacer,180deg,red braided hose covers,engine bay paint,Eibach springs,mevo control arms,Alpine IVA W505 with blk bird,Alpine rear cam,Hemi mats,RT BT shift bezel,,Martin bros dragontails 275/40/20hankook,R1 concepts rotors, Hawk pads, paint calipers,RT Honeycomb grill,Carbon fiber nav bezel,carbon fibre shift knob,Rear spoiler, de molded,remote start/alarm,tint,10KHID, Red LED interior lights,predator,Hood struts,08 300c interior,kicker speakers,BT lock out.
    sulzerdrone's Avatar
    sulzerdrone is offline I killed the electric car...
    Oct 2008
    S**ttywack, B.C., Canada
    Bad ass mutha...
    E&G classic grill,Tint, custom fibre glass sub eclosure, Kenwood eXcelon DDX812 head unit, Alpine PDX 1.600 amp, JL audio W6 12" sub, A buttload of trunk rattles, Airaid CAI, Predator 93 octane CAI tune, and Eibach 1.5" lowering springs.
    I hate to advocate sex, drugs, violence or insanity to anybody, but they've always worked for me.
    - Hunter S. Thompson
    V_G's Avatar
    V_G
    V_G is offline 1 Hell Of A Cool Vanilla
    Jan 2008
    B.C. Canada
    Nice job bro!! Im jealous
    06 3.5L Cool Vanilla
    MODS 22 inch Boss 304 rims, dual exhaust, E&G mesh grill, chrome side mirrors, tinted front and back windows, lowered, AFE Stage 2 CAI, BT custom front hood emblem, BT rear emblem, BT pistol grip shifter knob, BT designer series knobs, BT custom visor disguisers, 8000K HIDs, hood struts, demolded, many more to come....
    DannyBoy's Avatar
    DannyBoy is offline Si vis pacem, para bellum.
    Po-Compton, BC, Canada
    e x c e l l e n t !
    "Good Guys wear Black. And Blue."
    "Batman"
    teamo's Avatar
    teamo is offline LX Guru
    Maple Ridge B.C.
    that looks awsome Ed cand wait to see it run down the track
    ms mopar's Avatar
    ms mopar is offline Mopar Freak
    Jul 2008
    Vancouver
    it does look killer, can't wait to see what kind of times it gets in the 1/4 mile
    airraid CAI, airraid TBS, engine cover airbrushed , eye lids, blue LED's on headlights, led tailights, pinstriping on hood and liftgate, liftgate shaved, de-molded, 15% tint to rear, billet grill, 2" drop, 22" TIS wheels, 265/35/22 Hankook tires,Compu Star Pro alarm remote start and paging system, power slot rotors with ceramic pads, resonators delete , blue led lighting under car,blue led interior lights, airbrushed interior peices, Diablosport Predator
    MAGUIRE's Avatar
    MAGUIRE is offline Ross
    Jun 2008
    Langley
    May the Boost be with you, Let's see some video's!!
    2001 RR HSE 4.6 - Daily Driver
    2006 SRT8C - Stock
    1992 C4 Vette - Parked awaiting a transplant
    chris_stx's Avatar
    chris_stx is offline tx magnum
    Mar 2008
    Oak Cliff,Tx
    Man that looks good can't wait tell I can get mine.
    Firewalker's Avatar
    Firewalker is offline Black cars look better in the shade
    Mar 2009
    Maple Ridge
    all I can say is WOW! nice job!
    FW
    SKULLBOY's Avatar
    In A Bunker......
    Quote Originally Posted by Firewalker View Post
    FW
    How'd you make out with that Template Murray????
    HEMI Registry #1575
